moog 844 swap pics
moog 844 swap pics
first pic before spring
last two are after swap
before LH .......... RH
34 3/4 .......... 34 1/4
after 36 1/4 .......... 35 7/8-to36
after drive
to settle 36 .......... 35 5/8
no difference in ride harshness.truck is more sure footed.
shims i had in before maybe raised it 1/2-3/4"
BEFORE:
AFTER:
back is stock.the truck has the highest g.v.w for a 1/2 ton(can't remember code).had 4 leaves in back if i remember right.when i got the truck it had a massive rake to it .i initially put in rubber spacers in between front coils and it kinda helped. and have 31x10.5/15 wrangler duratracs(awesome tires).
How did you figure out those would fit your truck? I did not see it match up on the Moog website. I was considering putting the front leveling coil springs on mine.
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=46
did a search.lots of info on here about the swap.they are for an early 80's f250 2wd if i remember right.
Ford Truck Enthusiasts Forums - Search Results
bismic
08-10-2015 10:35 AM
HkyswiM
12-26-2011 05:41 PM
