Harmonic Balancer HELP!!!!!
Old Sep 10, 2010 | 05:24 PM
Adamjmerideth's Avatar
Adamjmerideth
Alright so I have a '91 f350 6x4 351w 16x,xxx miles
So i was driving down the road and my truck started shaking like crazy and was making a tearable clanking noise. so i pulled over climbed under the truck to find metal shavings everywere and the (big metal ring) around the pully was totaly lose. so here are my questions:
is this normal to break?
what would have caused this... age?
is the front seal easy to replace once the pully is off?
is anything else that should be done at the same time as this?
thankyou in advance for all of your help.
-Adam
Old Sep 10, 2010 | 05:28 PM
Adamjmerideth
also the the truck has been making a clanking noise above 3500 rpms could that have been it?
Old Sep 10, 2010 | 06:52 PM
rla2005's Avatar
rla2005
I have heard of a few harmonic balancers letting loose on this vintage truck. And yes it is caused by age. It most likely was your noise above 3500 RPM.
I have never replaced a front seal on a 7.5L engine, I cannot answer how easy it is to replace.
Old Sep 10, 2010 | 07:02 PM
jemini's Avatar
jemini
Harmonic balancer failed.
"is this normal to break?" YES especially with the miles on your truck
"what would have caused this... age?" YES
"is the front seal easy to replace once the pully is off?" REASONABLY
"is anything else that should be done at the same time as this?"
I would check timing chain cover and surrounding area for damage. Other than that, I would replace the timing chain seal (that the harmonic balancer goes through). Check the tightness of the timing chain cover bolts once the balancer is off. Borrow the harmonic balancer removal and harmonic balancer installer tools (2 different tools) from Auto Zone. The job should be reasonably straight forward - at least it was on my 88 F250.
Old Sep 10, 2010 | 07:07 PM
UglySinceBirth's Avatar
UglySinceBirth
I had the same problem on my 89 302. the balancer drove me nuts when it started to give out. I thought the u joints were bad, rear was bad, driveshaft was bent. Finally when it snapped and I replaced it some of my sanity did return. Unfortunately the rest is lost forever.
Old Sep 19, 2010 | 09:32 PM
Adamjmerideth
hey guys sorry it took me so long to get back with the results. The repair went smoothly and i did replace the timing cover seal. The new balencers info sheet said the main resone for failure was oil leak and bad ignition timing ...i had both After replacing the truck never ran so well (I've had it for 4000 miles) even got 1 more mpg.
Once again thankyou so much for all of your help
Old Sep 20, 2010 | 07:47 AM
jemini's Avatar
jemini
"It's nice when a plan come together" Glad it went well. It's amazing how a new balancer improves the overall ride - it did that in my case too.
Old Sep 20, 2010 | 07:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The new balancers info sheet said the main reason for failure was oil leak and bad ignition timing.
The real reason harmonic balancers fail has nothing to do with oil leaks or ignition timing, it has everything to do with age.
At the factory, a thin rubber insulator is placed between the outer pulley and inner damper, then all three parts are pressed together to form a one piece assembly.
What happens: The rubber shrinks, age cracks...then the outer pulley walks away from the inner damper.
If not caught in time, the pulley can completly separate from the inner damper and end up in the radiator core...not pleasant.
Old Sep 20, 2010 | 08:41 PM
TexasGuy001's Avatar
TexasGuy001
I have the original balancer and was thinking about this possibility. With almost 300K miles on the truck, its probably not a bad idea. Which replacement one is the best?
Old Sep 21, 2010 | 12:35 AM
BEWOLD's Avatar
BEWOLD
Not saying age wasnt a factor, but incorrect ignition timing can cause an erratic rough running situation causing unwanted torsion and harmonics. factory balancers only dampen harmonics in a narrow band, and anything abnormal can cause premature failure of the elastomer. Most factory balancers are very cheaply made which doesnt help either. Front seal leaks oil, oil gets on rubber, rubber shrinks and swells from oil, rubber cracks, balancer fails.
Bad1993
1978 - 1996 Big Bronco
May 24, 2017 01:35 PM
Bill W
Apr 21, 2017 05:48 PM
kyle j
Feb 5, 2017 06:43 PM
rayjavu
Nov 11, 2009 08:39 PM
Creedog
Dec 11, 2008 07:48 PM
