1996 302 - to dual quad or not?
I'm picking up my new 1996 302 out of a Bronco on Saturday for my '51 F-1 project. I'll be swapping out the EFI for an intake and carb. All was going well while I was shopping the intake/carb until the darksider in me started thinking about a dual quad setup. So here's a little background;
This truck will be a daily driver for me, but only in the summer (not much more than 4 months up here). But I also want it to be a formidable foe at a stop light.
I've never cared much about mileage, but I would like to see it at least up above 10-12 in town.
Also there will be a 5spd behind this, probably a T-5.
So if I take a stock '96 302 and simply bolt on a dual quad setup will I see a lot more performance or will I just burn it rich like crazy because the air won't keep up with the fuel?
Any info/suggestions appreciated!
- Joe -
- Joe -
You will most likely burn rich because the air won't keep up with the fuel. You need better heads to use that much carburetor.
The other thing is, I thought dual quads were more for high rpm power. You really want something with low rpm torque in a truck.
You will definitely need to build the engine with very good heads, cam and exhaust to
effectively use dual 4bbls. The original Shelby and Ford dual quad setups were just
like the big block setups in that they ran off the primary side of both carbs all the time.
Not real good for mileage. They had Holley carbs with vacuum secondaries. If you
want a cool looking and great running setup that would also give you decent mileage
and great driveablity, consider a 3 2bbl setup like the original Cobra kits offered.
why not go efi, i wouldnt run what that bronco had in it but get yourself a mustang mass air efi harness and computer. you can leave all of the efi stuff on that 96 motor and that mustang harness will hook right up. doesnt get any easier than that and you will get great driveability and better mileage
A single 500cfm 4bbl is overkill for an all stock 302.. the heads and cam are simply too small. 275hp is all it will make with a wide open headers and a single plane intake on an engine dyno... and it takes more than the stock truck cam to get that output.
Thanks for the replies guys!
The 3X2 intake and carbs are still avialable as reproductions of the originals. Do a Google
search and you can find sources. The originals are very expensive and the repos are
about the same as a dual 4bbl system. I still have an original system that I ran on on
a stock 1968 302 4bbl engine and they ran great.
Three deuces? Summit sells a ready-to-run set up. Be prepared to swallow your testes, though...
Summit Racing SUM-CSUM1906 - Summit Racing® Triple 2-Barrel Combos - Overview - SummitRacing.com
COMP Cams 35-410-8 - COMP Cams Magnum Hydraulic Roller Camshafts - Overview - SummitRacing.com
Dart 13301181 - Dart Iron Eagle Cylinder Heads for Small Ford - Overview - SummitRacing.com
Racing Head Service 35304-01 - RHS Pro Action Small Block Ford Cylinder Heads - Overview - SummitRacing.com
Looks like the dual quad setup can be gotten for less than the tri-power:
Edelbrock 20354 SB FORD Dual Quad Manifold Carb Kit: eBay Motors (item 190441457690 end time Sep-14-10 15:55:05 PDT)
For ultimate coolness at a similar price:
Ford V8 Webers 818 764-1901
A '96 302 has a roller cam in it so go with something like the Comp Cams 34-410-8 and RHS or Dart irons with a 170-185cc intake ports and 58cc chambers. With these heads peak power(360-375hp) is upwards of 5500-6000rpm so you can ignore the "RPM" range" on the Summit page. A cam like this will also deliver half decent low end TQ compared to an E303 for example so you won't need a high stall and 4.56 gearing.
Lots less. you can grab the Edelbrock F-28 intake for about $285 on eBay, intake only, no carbs.
fakirone
39
Sep 1, 2015 11:24 AM
Turbo Dog
25
May 8, 2014 01:24 PM
baffledinpa
Oct 8, 2008 12:13 AM
imlowr2
Aug 9, 2008 11:19 AM
