truck bed sides
Old Sep 9, 2010 | 07:37 PM
zombiefied 247's Avatar
zombiefied 247
truck bed sides
ok,I will try to explain this best I can. on the top of the bed sides where it goes into the roll is there an easy way to straighten these out without replacing the bedsides????
Old Sep 9, 2010 | 10:57 PM
51PanelMan's Avatar
51PanelMan
I don't think so. What might work, in theory, is if you heat the area bright red and stick a metal tube inside the whole all the way through. This might help to straighten the area. You'll need to finish it with some body filler.
Another way is to shape it with body filler or build up welds in the area and grind smooth.
Old Sep 10, 2010 | 01:18 AM
keith56_cruz_cab's Avatar
keith56_cruz_cab
I tried straightening mine ...over corrected be carefull.
Old Sep 10, 2010 | 02:32 AM
POS-F500's Avatar
POS-F500
You could also pick up/borrow/etc a stud welder and dent puller.
You can find cheap'os at Harbor Freight for about $100.
Old Sep 10, 2010 | 09:28 AM
bobj49f2's Avatar
bobj49f2
Here's my idea; Make a couple of different diameter pieces of steel rods, with both ends ground to a dull point, about 3-4 inches long. The first just a little larger than smallest dent and push it through with a slightly smaller steel rod. Once you're able to send it through without a problem use a larger diameter plug and progress until you have the dents worked out. If you have some particularly bad dents you could have some one heat the area with a torch while pushing the bullet through.
By using a plug you have less of a chance of getting a full length of steel rod stuck in the tube and also you will only need short pieces of different diameter rod. You don't want the plug too short to decrease the possibility of having the bullet getting cocked in the tube. The double point would make it easier to push back if it gets stuck.
Old Sep 10, 2010 | 11:50 AM
CharlieLed's Avatar
CharlieLed
I have cut the rolls off completely and welded on 1-1/4 tubing in its place. If you have the tools and skillset then this is a clean way to fix a number of issues with the top rails.
Old Sep 10, 2010 | 12:08 PM
bobj49f2's Avatar
bobj49f2
That's what I did on my F-2, I used black water pipe with the same OD as the original tube. I also beveled the ends a little to knock down the thickness so they looked more like stock. The black pipe will never dent unless you drop some massive weight on it.
Old Sep 10, 2010 | 08:00 PM
zombiefied 247
thanks for the tips, not sure how i am going to tackle this yet but at least now i have somthings to consider.
Old Sep 10, 2010 | 08:56 PM
fordman75's Avatar
fordman75
Mine was pretty beat up too. So I'm just going to make some new sides and save the hassle. The metal I'm using for the sides is going to cost me just over $100 for the pair. And since I plan to use the box for hauling stuff I'm going to use some heavier wall tubing for the top roll. Then just weld it to the new box sides.
Old Sep 10, 2010 | 11:25 PM
malatious's Avatar
malatious
I was thinking about just cutting out the section that was bad and welding a new piece in. Seems like that would be easier than replacing the whole tube.
Mal
Old Sep 10, 2010 | 11:33 PM
fordman75's Avatar
fordman75
Hey whatever works!
Old Sep 11, 2010 | 08:33 AM
3golfjack's Avatar
3golfjack
One thing about these old trucks Mal is you can have it your way. I think the best way is to if your not sure ask for advice and pick the way you want to do it. If you do weld just take your time and don,t wrap the metal.
alconk
Oct 7, 2008 06:31 AM
twillard
Sep 6, 2007 08:01 PM
dbarney1971
New Member Introductions
May 18, 2007 11:03 PM
deanme
Mar 23, 2005 10:33 AM
