Axle Leaking
Old Sep 9, 2010 | 05:22 PM
rmalottwtes30's Avatar
rmalottwtes30
Axle Leaking
What all is involved to fix a dana 60 that is leaking gear oil out the axle seal on the passenger side, where the axle goes into the casing.
This is one of my last major fixes.
Old Sep 9, 2010 | 05:24 PM
oreocreaming's Avatar
oreocreaming
were talking front dana 60 right? if so, is it kingpin or balljoint axle?
Old Sep 9, 2010 | 05:29 PM
rmalottwtes30
Ya my front axle and its ball joint
Old Sep 9, 2010 | 05:33 PM
oreocreaming
are you talking about the seal on the axle tube or on the knuckle? by casting im not sure what end your talking about.
Old Sep 9, 2010 | 05:35 PM
oreocreaming
either way, remove the hub, remove the internal gears and get a bearing socket (keyed) to remove the nut and bearings. remove the nuts for the ball joints, remove the knuckle from the axle and you can get it from there. Pirate4x4.Com - Extreme Four Wheel Drive
Old Sep 9, 2010 | 05:37 PM
oreocreaming
https://www.ford-trucks.com/forums/9...help-asap.html socket is pictured there
Old Sep 9, 2010 | 05:44 PM
rmalottwtes30
What is the seal called that I need?
Where the universals/Axle go into the axle casing is where it leaks
Old Sep 9, 2010 | 07:26 PM
powerstroker100's Avatar
powerstroker100
yeah thats a big ol seal in there what oreo showed is good, check this out too, scroll down the page they have step by step rocedure that will eventually get to pulling that axle out and the guy shows how to make a new seal installer and the parts only cost a few bucks from HD 2004 F250 Ball Joint Replacement
Old Sep 9, 2010 | 08:00 PM
rmalottwtes30
I was told by someone that I had to remove the carrier and pretty much tear it all down to replace the seal. Someone have a part number for the seal?
Old Sep 9, 2010 | 09:17 PM
farmert's Avatar
farmert
You have to compleatly disasemble the front to replace the seal, as the seal installs inside the pumpkin. One on each side where the axle enters the pumpkin.
Old Sep 9, 2010 | 10:51 PM
wreckinball's Avatar
wreckinball
just curious but is your differential vent tube clear? Mine was clogged like crazy so much so that i had to drill it out! When i did that it has yet to leak almost a year later.
mark996
Jan 25, 2014 11:46 AM
78 RedandWhite
Dec 3, 2010 02:40 PM
Shanemh
Feb 14, 2009 02:55 AM
mikefender
Apr 21, 2007 09:16 PM
markbrumbaugh
Oct 18, 2006 06:17 AM
