need help asap
Old Sep 4, 2010 | 04:34 PM
joe f350's Avatar
joe f350
need help asap
YouTube - im stumped
moms a 375 that packs 380 betrra i tried dropped the spindle toand pull it as one unit that dint work
Old Sep 4, 2010 | 04:44 PM
greywynd's Avatar
greywynd
Joe, is there not a big nut inside there? This is where you need the spindle nut socket, which is a special tool, but you may be able to rent/borrow or buy one at the parts places.
Old Sep 4, 2010 | 04:48 PM
joe f350's Avatar
joe f350
no nut just that dam gear
Old Sep 4, 2010 | 05:08 PM
bill11012's Avatar
bill11012
Modular motor junkie
The nut kind of looks like a gear... kind of. Any body have a pic of one?
Love the hose clamp.
Old Sep 4, 2010 | 06:19 PM
macman85602's Avatar
macman85602
This should be the correct tool to pull it apart
If you were closer i would let ya use it
Scott
Old Sep 4, 2010 | 09:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Joe, somewhere around 4 or 5 seconds into your video, I see the notches in the spindle nut.
Takes a socket like the one in Scott's post.
Do be aware there are several versions, 4 and 6 prong with several different diameters.
Old Sep 4, 2010 | 10:34 PM
joe f350's Avatar
joe f350
thank guy i found one it tokk about 2 hours of tracking it down but i got one side striped to the spindle but the slip over clip on the other is not wanting to come out
Old Sep 5, 2010 | 12:28 AM
rupejosh's Avatar
rupejosh
that clip can be a bear to get out
Old Sep 5, 2010 | 01:18 AM
joe f350's Avatar
joe f350
i tried a hour befor i gave and called it a night so next i try tomaro
Old Sep 5, 2010 | 05:27 AM
rupejosh's Avatar
rupejosh
so are you saying mama is mad at the end of the video?sounds like my ole lady on a good day......
Old Sep 6, 2010 | 03:06 PM
johnboggs21's Avatar
johnboggs21
is this what ya called me about the other day joe? Told you ya probly needed some kind of special socket.
I swear, you old guys, cant tell ya nothin LOL jk
Old Sep 6, 2010 | 03:15 PM
Otahyoni's Avatar
Otahyoni
Couldn't tell if you got it Joe, but there is a wire ring just inside the hub there that holds the body of the hub lock in. What i did to take mine out was take my pocket knife and pry the end out of the groove, then take something with a hook on the end (a bent paperclip is just fine) and grab that wire and pull it out.
Then that aluminum body will slide out, then the nut is right behind it. You'll need the socket posted above for that.
Take that nut out and the whole hub slides off the spindle. Then you'll see the nut that hold the spindle on, and after you remove those and the spindle the axle will slide right out.
Old Sep 6, 2010 | 03:19 PM
Otahyoni's Avatar
Otahyoni
Joe, try taking the thin bolts that hold the hub lock on and thread them into the holes in that aluminum body and try working it out like that...
Old Sep 6, 2010 | 04:09 PM
joe f350's Avatar
joe f350
yea i got it
