Front axle leaking
Old Dec 2, 2010 | 08:28 PM
78 RedandWhite's Avatar
78 RedandWhite
Front axle leaking
My front Dana 44 is leaking out the axle tube. My question is the only
way to fix it is to remove the carrier (differential case) ?
Thanks
Old Dec 2, 2010 | 08:31 PM
akforceten's Avatar
akforceten
yes you have to remove the diff carrier to replace the axle seals
Old Dec 2, 2010 | 08:48 PM
78 RedandWhite
Thats what i thought but wonted to ask to make sure
Thanks
Old Dec 2, 2010 | 09:05 PM
akforceten's Avatar
akforceten
your welcome
Old Dec 3, 2010 | 02:40 PM
lostinfords's Avatar
lostinfords
make sure you have the correct axle in there first, some 44 front axles are larger...ie the 78/79 hd 44 in the f150 4wd supercabs are larger than the f150/bronco 4wd
DanielT28
Apr 13, 2014 06:19 AM
PRexcursion
Sep 27, 2011 04:40 PM
Jspafford
Jun 16, 2007 01:11 PM
Jared Putz
17
Nov 10, 2003 03:19 PM
F0rdF0rever
Sep 16, 2003 06:16 PM
