Sponsored by: Real Truck
Tire size
Old Sep 9, 2010 | 12:27 AM
musclecars90's Avatar
musclecars90
Tire size
Hi everybody
What is the biggest size tire I can put on my truck. Its an 04 f-350 with a leveling kit. It does not matter if its a metric tire or standard tire.
Thanks for any replies
Old Sep 9, 2010 | 01:49 AM
FI460's Avatar
FI460
You should fit 35's with a levelling kit.
Old Sep 9, 2010 | 10:51 AM
cartmanea's Avatar
cartmanea
35x12.50 should fit, but it depends on wheel offset as well. What size wheels are you running?
Old Sep 9, 2010 | 02:01 PM
ExplorHer1369's Avatar
ExplorHer1369
Yep, need wheel info.
Old Sep 9, 2010 | 06:45 PM
musclecars90
Sorry I meant to put stock wheel. I just cant find an aftermarket wheel that I like
Old Sep 9, 2010 | 06:56 PM
cartmanea's Avatar
cartmanea
What size? 16? 17? 18? I wouldn't go as wide as 12.5" on a stick rim.
Old Sep 9, 2010 | 11:33 PM
FI460's Avatar
FI460
I believe stock wheels are 8" wide. Most people recommend 10" wheels for 12.50's
Old Sep 10, 2010 | 06:28 PM
Sleepsafe's Avatar
Sleepsafe
I have an F250. I run 35x12.5 on stock 18" wheels. I had to trim a tiny bit off of my mud
flapt to avoid rubbing at full lock. Lots of room. I used a Icon 2.5 inch leveling kit. I believe the F350 would use the same kit.
Old Sep 10, 2010 | 08:33 PM
jdboy's Avatar
jdboy
The factory 16" wheels on my 03' Lariet were 7". I think the later model 17's and 18's are wider though. If you have the earlier 16's like mine you can get a 35x10.5x16 from Super Swamper. This is the size I was going to run before I found my setup. By the way, I'm running a leveling kit with 35's but had to space my inner fenders back a little and trim the lower valance just a bit.
Bud Mud
May 23, 2014 07:40 AM
Wstrombe
Nov 27, 2002 11:25 PM
qwpo
Jul 30, 2002 08:19 PM
bigFAWKINranger
Jul 12, 2002 01:58 PM
Curtis360
1997 - 2003 F150
May 26, 2002 09:48 PM
