Sponsored by: Auxito
tire size
Old Apr 2, 2002 | 02:27 PM
Curtis360's Avatar
Curtis360
tire size
Old Apr 7, 2002 | 10:54 AM
texacejr's Avatar
texacejr
tire size
Need a lil bit of info here guys..
Just purchased a 1997 f-150 4X4 with the lariat package.
Truck is sweet but I'm wondering about maximum tire height without any mods (lift kits, etc..). Currently running 265/70R17 tires (appx. 31/10.5). Was wondering if 33/12.5 tires will fit without rubbing??
Other than tires my only performance mods will probably be Cat-forward header system, Cat-back duals to the rear, K&N air filter and maybe a B&M transpak. May also go with a cobra style hood with cold air induction when money allows (teens are expensive to raise and I have 3 of em).This truck is my new daily driver and grocery gitter *laughing*, so it has to be reliable but still fun to drive.Appreciate any help ya'll can offer.
Old Apr 8, 2002 | 10:55 AM
BEEV97's Avatar
BEEV97
tire size
hey bro for about 65 bucks you can do the block the rear end and tweak the torsion bars but if completely against it the biggest i could get was a set of bf goodrich 295/75 r16
Old Apr 19, 2002 | 05:10 PM
blackthunder's Avatar
blackthunder
tire size
from what i understand man is that if you get 15" wheels 33's will fit but it will look to tight in the wheel well
i have a 2000 with 265/70/17 mickey thompson mtx radials that i got today
Old May 26, 2002 | 09:48 PM
rkjerue's Avatar
rkjerue
tire size
I have done some research because I am in the same situation you are with my 2000 F-150 4x4. A 275/70-17 will work for sure it is about an 1" taller and an 1" wider. A 285/70-17 might work but I have been told they might be to large. I found some different tires in these sizes at http://www.tirerack.com/
(Some good options)
275/70-17
- Goodyear Wrangler GS-A 275/70-17
- Goodyear Wrangler AT/S 275/70-17
- Goodyear Wrangler MT/R 275/70-17
285/70-17
- BFGoodrich MT
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
