Electrical Issue 77 F100
Old Sep 8, 2010 | 11:29 PM
doctorgoo's Avatar
doctorgoo
Ok so here's what I did. My truck would not start. Everything else seemed normal, but no start. I did the old pliers across the starter solenoid thing to see if it needed to be replaced. The truck fired right up, so I replaced the solenoid. When I tried to start it up again, I found that the radio, interior fan, and wipers do not work and the truck will not start. The headlights, taillights, interior light all work fine. I think I may have fried something. I checked for blown fuses in the box by the brake pedal and didn't find any. What should I try next?
Old Sep 9, 2010 | 09:42 AM
fmc400's Avatar
fmc400
MSEE
Is there any chance a previous owner has hacked up the wiring? It doesn't make sense for part of the electrical system to function, yet all the fuses are good. If that's the case then the only way you can solve this problem is to trace all the wiring back through the truck and see where power drops out.
Old Sep 9, 2010 | 09:44 AM
Bdox's Avatar
Bdox
Look for a fusible link failure.
Old Sep 9, 2010 | 02:47 PM
kendooley's Avatar
kendooley
You have 2 seperate issues. Check the fuses with a multimeter. Just 'cause they look good, doesn't mean they're not burnt where you can't see.
Second, you're solenoid isn't the problem. If the truck has an auto trans, it's your park/neutral switch. If it's a stick shift, the clutch switch isn't working right.
Old Sep 15, 2010 | 12:49 PM
doctorgoo's Avatar
doctorgoo
I found the problem. The ignition switch was fried. thanks for the replies.
bttf
Sep 14, 2013 03:36 PM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
86supercab
17
Jun 6, 2010 10:32 PM
56Jeff
1978 - 1996 Big Bronco
Oct 6, 2008 01:31 PM
jessica
Jul 14, 2002 10:35 AM
