94 f350 trans problem
Old Sep 8, 2010 | 08:16 PM
SoupCan™'s Avatar
SoupCan™
ok guys..i have a 94 f350, 4x4,7.5l with an e4od..the truck was beat pretty hard and then parked for about a year,i purchased it without being able to testdrive...anyway one of the repairs i had to do is the wiring harness going to the trans was all chewed up..while doing the brakes and front axle, i changed the trans fluid/filter, found no debris in the pan..now if i drive it, reverse works fine..but if i try to take off in drive it acts like its slipping...but if i start in 1st and manualy shift up..it works ok..and the same if i start in 2nd...i havent had a chance to check the mlps yet, but i did the self test that you do without it running, and got these codes 621,622,624,626,629,637 and 539...can anyone help? i am not sure if these were "stored" codes or not...
Rich
Old Sep 9, 2010 | 02:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
All of those codes are electrical faults for circuits that are in the wiring harness going to the transmission. I suspect you didn't fix the wiring harness correctly. None of the codes are for the MLPS.
jlarr
Jan 4, 2015 09:47 PM
94BigGulp
21
Dec 9, 2014 08:37 AM
Dennis-Pa
15
Aug 30, 2013 08:16 AM
jeepzj94
59
Dec 20, 2012 12:45 PM
SoupCan™
Sep 8, 2010 10:06 PM
