head light trim
Old Sep 8, 2010 | 10:33 AM
southern hunter56's Avatar
southern hunter56
head light trim
can someone please tell me how to remove the headlight trim on a 92 f150,I need to replace the headlights due to fogging, it has 334000 miles and they are due for a change thanks for any help. Southern hunter56
Old Sep 8, 2010 | 10:56 AM
nstueve's Avatar
nstueve
Save yourself the cash... this product works great! i have used it several times on my 22 year old trucks and it brings a nice shine back to the lenses...
Headlight Restoration | Headlight Cleaner
Old Sep 8, 2010 | 01:34 PM
southern hunter56
headlights
Thanks for your reply but I tried the kit and it worked somewhat, but the inside is clouded over. I got both headlights for $45.00 on ebay with bulbs and free shipping I think the kit costs more, I dont remember but I returned it Thanks again. Southern hunter56
Old Sep 8, 2010 | 02:16 PM
nstueve's Avatar
nstueve
in that case you have to remove the entire headlight assembly by the bolts in the engine bay... once out you can disassemble the headlamp.
Old Sep 8, 2010 | 02:41 PM
southern hunter56
headlights
there is noway to just remove the beazel to get access to the headlight
Old Sep 8, 2010 | 05:03 PM
*2fords*'s Avatar
*2fords*
I just replaced my whole header panel thanks to a couple of wrecks. I can tell you there is no way to remove just the headlites themselves. There are 2 nuts inside down behind the battery tray and the vaccuum canisters on the other side. I found it easier to remove all the stuff in the way of getting a straight shot with a ratchet and socket.
Also underneathe the truck there are 2 bolts on eachside that hold the front of the fender skirts in place. If you take those bolts out you can bend the front of the fender skirts down out of the way and bungie them back to the spring or something suitable to hold them. This gives you easier access aswell to those nuts.
Old Sep 8, 2010 | 05:04 PM
White 97 xlt's Avatar
White 97 xlt
Go back and READ post #4.... The headlight assemblies bolt in from the engine side of the radiator support!!
Edit: Read post #6 also!! He posted while I was typing...
southern hunter56
Feb 4, 2011 12:54 PM
southern hunter56
Jan 28, 2011 09:39 AM
southern hunter56
Jan 6, 2011 12:40 PM
southern hunter56
Aug 30, 2010 07:39 PM
