compare
The 7.3 has 6 heavy duty bolts per cylinder where as the 6.0 has 4 torque to yield bolts per cylinder. With the TTY head bolts they are designed to stretch and hold the head down that way. They are also only torquewd to 85 ft-lb. When the 6.0 is pushed hard, like pulling a trailer up a grade, the pressures in the motor can stretch those bolts and blow the head gasket out. This can be fixed by getting ARP head studs which replace your 85 ft-lb TTY bolts with studs that get torqued to something like 240 ft-lb (or something in that ballpark).
Another thing the 6.0 has is a variable vein turbo charger. The blades in this turbo move according to how far down you're pressing the skinny pedal essentially increasing the size of the turbo to help it spool faster when needed and push more air into the motor. The variable veins have a tendency to get gunked up from carbon or other crap. To keep it working correctly just gun it a few times every once in a while and it will make sure they're broken loose and working properly.
Another thing on the early 6.0's is that the wiring harness on top of the motor had a tendency of getting crushed.
Don't let me discourage you from getting an early 6.0, they are good trucks but you just have to realize that there are a few inherent problems (as there are with any motor). There is a Power Stroke expert out in Kentucky I believe who has a YouTube page FULL of videos on the Ford diesels. He describes differences between all the motors and has a ton of information on all the motors. Her's the link for you: YouTube - powerstrokehelp's Channel
Anyone feel free to correct me, I'm not perfect!
