Wacky gear shift/ABS problem
Old Sep 8, 2010 | 07:47 AM
diz71266's Avatar
diz71266
OK this is weird...I have a 98 E150,and when I attempt to put the van in gear the shifter wont move and the ABS light begins to flash..UNLESS!.. I turn the key a slight bit forward,and then the gear shift will move and the ABS light will turn off. The ABS light will remain unlit untill I come to a complete stop, BUT THEN!.. it will come on again.Now if im driving somewhere where I know im not going to stop for a while (highway) I can nudge the key forward in the ignition and the ABS light will go off again.As long as I dont come to a complete stop it will stay off (I could go 1 mile per hour and it wont come back on).
My brother is a mechanic but lives a bit far for him to fix it ..he says he thinks it might be an ignition problem....any ideas?
BTW I have no problems braking and I only have rear wheel ABS.I also read somewhere tha # of flashes the ABS light makes could be signalling the issue..it flashes 15 quick times, then one long time. then starts over (like 15 dots and one dash in morse code)
Old Sep 20, 2010 | 08:15 AM
diz71266's Avatar
diz71266
I cant get a single opinion on this?
there must be someone who has an opinion...or at least where else I could go for help
Old Sep 22, 2010 | 10:37 AM
gearloose1's Avatar
gearloose1
Replace the ignition lock cylinder and see what happens.
Old May 15, 2011 | 12:58 PM
diz71266's Avatar
diz71266
Fixed it!
If you had this same problem ..see how I fixed it here>>>
https://www.ford-trucks.com/forums/1...l#post10343998
v8xploder
1978 - 1996 Big Bronco
Jun 25, 2011 09:18 PM
f-150 hot rod
Apr 11, 2008 07:12 AM
mainstreet1984
New Jersey Chapter
Jun 10, 2007 09:09 PM
Aegerter36
May 8, 2003 10:39 PM
