Clunking noise
Old Sep 8, 2010 | 06:05 AM
Duke78's Avatar
Duke78
Clunking noise
I have a clunking noise that occurs when I mash on the gas in 2nd gear. Sounds and feels like the transmission is hitting the cab. I have a 78 with a 300I6, NP 405 TC and an NP 435 4 speed manual transmission.
I can feel it in the floor board under my right foot. I'm not sure what it could be, the motor mounts are as tight as i can get them, but it seems like the shifters are moving a lot more than they should be. Please help.
Old Sep 8, 2010 | 06:42 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Did you check the tranny/transfer case mounts also? Can't recall if that TC has the side mount too.
Old Sep 8, 2010 | 07:05 AM
Duke78's Avatar
Duke78
It does and i have that as tight as i can get it also. Nice Bronco...
Old Sep 8, 2010 | 09:14 AM
Ford_Six's Avatar
Ford_Six
They may be tight, but how's the rubber holding up?
With the hood open, you should be able to see the engine a bit from the driver's seat. Start it, out it in gear, and slowly let out the clutch with the brake still on. If the engine moves more than a little, the mounts are torn, and need to be replaced.
Old Sep 9, 2010 | 05:44 AM
Duke78's Avatar
Duke78
I tried your method last night with the brake on, i could move the motor ~1", just looking at the oil filler cap. I also was able to re-create the clunking noise by letting the clutch out.
So i think i will replace the motor mounts and the tranny mount to see if that helps. I just restored this truck and it didn't do this before, i can't remember if the mounts looked worn out or damaged. They are cheap enough to just replace though.
Thanks for the replies i'll post the results from new mounts in the near future.
Old Sep 13, 2010 | 10:19 PM
pontiacbird93's Avatar
pontiacbird93
take them with you when you go to parts house liked to have never found passenger side motor mount for my 79 4x4 4 speed auto zone, advance, and bumper to bumper found it at bumper to bumper under a part number for a 84 4x4 weired
Homerunking2394
Nov 9, 2015 01:57 PM
Primerranger
Mar 12, 2015 06:11 PM
Ford Guy87
Feb 13, 2015 03:48 PM
stanimals2
1997 - 2003 F150
Jan 5, 2014 06:54 AM
hunter1897
Aug 3, 2008 12:01 PM
