Push Rod Cover
Old Sep 7, 2010 | 01:12 PM
emgee's Avatar
emgee
Push Rod Cover
I need to replace the push rod cover gasket on my 300 ci six. Does anyone have the bolt tightening sequence and torque specs for the bolts? My Haynes manual doesn't even cover this ... maybe Chilton's does but it's not readily available.
Old Sep 7, 2010 | 03:07 PM
Monte1go's Avatar
Monte1go
I couldn't find anything about the sequence or torque specs either so I just started in the center and worked my way out and tightened the bolts pretty snug. I haven't spotted any leaks so far.
Old Sep 7, 2010 | 05:08 PM
Ford_Six's Avatar
Ford_Six
Snug is fine, don't over tighten it or you'll tweak the edges and it'll leak just as bad.
Old Sep 7, 2010 | 05:23 PM
emgee's Avatar
emgee
Sounds like that'll work fine. I can't see getting a basic torque wrench onto the bolt close to the distributor any way. Thanks for the information.
Old Sep 7, 2010 | 08:32 PM
AbandonedBronco's Avatar
AbandonedBronco
There isn't a lot of pressure, or oil, that the seal needs to keep in. It's mainly just an access cover (which I didn't realize how awesome it was until I worked on my brother's Jeep 4.0, which requires a head removal to access lifters!). Enough torque on the bolts to simply press the gasket works great. Center out is recommended too.
gtcrackers
15
Sep 13, 2020 11:30 AM
kjs5055
Sep 28, 2016 04:02 PM
rhino123
39
Jul 31, 2016 09:16 AM
doug42190
Jun 10, 2016 10:25 AM
burnthelight88
25
Aug 13, 2015 05:27 AM
