fuel system reset...
Old Sep 6, 2010 | 05:40 PM
jwiseman's Avatar
jwiseman
how does the fuel system reset button work? im having fuel issues and cant fig out whats the problem. the problem is it wont start lol...1999 f250 7.3TD
Old Sep 6, 2010 | 06:11 PM
zx250's Avatar
zx250
Of the next Riffraff East
First thing you need to do is make sure you have fuel getting to your fuel bowl. Opening the drain valve is the easiest way to do that.
Old Sep 6, 2010 | 06:28 PM
jwiseman's Avatar
jwiseman
yea, ive been threw all of these steps, i just dont know where to go now
Old Sep 6, 2010 | 06:35 PM
zx250's Avatar
zx250
So, no fuel to fuel bowl? Is your Wait to start light coming on at start up?
Old Sep 6, 2010 | 06:47 PM
jwiseman's Avatar
jwiseman
there is fuel going to the fuel bowl. actually the truck WILL start..and it will run perfect till i shut it off...the only way to turn it on again is with a shot of starter fluid, and the wait to start light IS comming on for the normal 10ish seconds...i can here the fuel pump on the frame under the driver seat running for like 30 seconds too.......idk
Old Sep 6, 2010 | 06:54 PM
zx250's Avatar
zx250
It's not your fuel reset or your fuel bowl heater. Don't use starter fluild, not good on our trucks at all, If you must use something, us WD40. Does it start ok after a long time setting? Give all the details you can and we can try to help.
zx250's Avatar
zx250
Or, do you always have to use starter fluild to start it?
Old Sep 6, 2010 | 07:03 PM
jwiseman's Avatar
jwiseman
even if i drive it all day, if i have to shut it off it wont start without starting fluid, i know its bad to use it but wd40 would not even work for some reason...it runs perfect while its running but it just wont start. i changed glo pulgs, gpr, batteries, air filter, oil/filter, and the water draino valve.. uhhh...i think thats all i changed, i checked the hpop, the starter is cranking fine, i can here the fuel pump, the exhaust smells strongley llike fuel...would that be..rich..? or lean? idk, there is OCCASIONALLY some white/light blueish smoke upon startup too
Old Sep 6, 2010 | 07:09 PM
zx250's Avatar
zx250
Is you oil level in the HPOP staying within an inch of the top of the resevoir? Are you sure you are getting enough cranking voltage? If you turn the key and wait a few minutes, will it crank better? this give the glow plugs time to cycle and will give you more power for cranking.
Old Sep 6, 2010 | 07:26 PM
jwiseman's Avatar
jwiseman
hpop level is good, has enough cranking power just wont start. i know its a fuel issue i jusdt dont know where to go next
Old Sep 6, 2010 | 07:33 PM
zx250's Avatar
zx250
If you got fuel to the bowl and you smell fuel at the exhaust, then I doubt it's a fuel issue. If you are a little off on cranking voltage, it will still sound like plenty of power, but not be enough to fire off. Low oil level in the HPOP will keep the injectors from firing. Other things will cause hard starts, but most will also cause poor running issues. Just for fun, hook up to another truck or charge your batteries for a while and try again. I'm still betting on weak batteries. Seen it too many times.
Old Sep 6, 2010 | 08:15 PM
7.3 Rocket's Avatar
7.3 Rocket
For s**ts and giggles pull the plug off your ICP sensor and check it for oil. It's the sensor next to the lifting eye on the drivers side.
Old Sep 6, 2010 | 08:23 PM
F350-6's Avatar
F350-6
Sounds like you would have been better off buying a scanner like AE instead of throwing parts at it.
If you must use starting fluid, at least disconnect your GPR so your glow plugs don't come on. It's only a matter of time before the glow plugs ignite the starting fluid before you start cranking and you end up needing a new engine.
How long has this been going on? Did it start suddenly, or get gradually worse? How many miles on the engine oil and is it full? Fuel and air filters good? How many miles on the truck and how often was the oil changed? Injectors original or replaced? When it's running, what does the blowby look like?
Glenn Blackwell
Aug 6, 2014 05:15 AM
gdw3138
Bronco II
Jun 24, 2009 08:59 PM
gunslinger67
1983 - 2012 Ranger & B-Series
Sep 12, 2004 10:03 AM
mnmsparky
Nov 16, 2002 12:21 AM
drought1
Mar 23, 2002 10:01 AM
