e40d lost second gear!!!
Old Sep 6, 2010 | 04:06 PM
89ford73's Avatar
89ford73
my friends truck lost second gear completely!! i think it is just a shift valve in the main valve body, but i could be wrong, it went from having strong perfectly working second gear to none at all, if i remember right, the brake band tightens up to make second gear???? or does it loosen up to make second? i dont remember! could it be a shift solonoid not working? stuck open-closed? i am going to pull the valve body and have worked on these transmissions before, im pretty good with them, i know what valve is for the 2-3 shift and the 3-4 shift, but i cant remember where the 1-2 shift valve is! if someone could post a pic maybe of the valve body for me that would be great! thanks
Old Sep 6, 2010 | 04:07 PM
89ford73's Avatar
89ford73
manual second creates first gear also, and drive skips 2nd goes straight to 3rd
Old Sep 7, 2010 | 06:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
To make second gear the intermediate clutch applies and the intermediate one way clutch holds. With the shifter in 2 (manual second gear) the intermediate brake band also applies, or tightens. The band is not used in automatic second.
The intermediate clutch is not applying or the one way clutch is not holding. The clutch could be a stuck shift valve. If it is the one way clutch it can only be a failed one way clutch.
Shaun lindmark
20
Sep 23, 2011 07:59 AM
84-250
1983 - 2012 Ranger & B-Series
Mar 13, 2010 03:12 PM
Agemenon
21
Dec 11, 2007 08:57 PM
Huntersbo
Apr 3, 2007 12:56 PM
Power_by_429
Dec 22, 2006 09:38 AM
