warped e40d case?
Old Sep 22, 2011 | 07:29 AM
Shaun lindmark's Avatar
Shaun lindmark
warped e40d case?
Hey guys how likely is it that my e40d case is warped. I had it rebuilt about 3 months ago and was fine until 2 weeks ago. lost reverse and 3rd gear. they it came back. since then it has been doing screwy things like starting out in second and wont shift. if you can get it to 40 mph it will shift into od but no tc lock up. one time it was shifting really early ex. Shifted into second right away, lock tc at 25, and then shifted into od at 30. lugged the engine pretty bad. did this in stop and go traffic for 20 min then just went away. its at the trans shop now and he said it could be something with the valve body or actuator for something but if all that checks out then he said alot of time the diesels will have wrped cases and he doesnt know what to tell me..... WTF ive never heard of such a thing
What dod you guys think
p.s these syptoms are very on and off. sometimes truck will drive perfect i dont get it
thanks for your thoughts shaun
Old Sep 22, 2011 | 07:40 AM
DIYMechanic's Avatar
DIYMechanic
Mmm, yeah... not buying that warped case explanation. Valve body issues, maybe... These transmissions are electronically controlled so all the shift points and TC lockup are controlled by the PCM. How does your speedometer look? Any bouncing in the needle while driving? The PCM uses the VSS on the rear diff housing to determine vehicle speed and to establish a map for shift points based upon throttle application, engine load, etc. If the VSS is acting screwy then the PCM will have a hard time shifting like it should. The other thing that can cause these issues is the electrical connector on the driver side of the tranny. If that connection isn't clean and tight then you can see some screwy issues as well.
Just out of curiosity, what was the transmission doing that prompted the rebuild?
Old Sep 22, 2011 | 07:49 AM
Shaun lindmark
I really hope your right. the reason he said it could be warped is because 3rd and reverse are on the same drum andthat reverse doesnt rely on any electronics or selionids. i had it rebuilt befor because it was taking forever to go into reverse and didnt want to shift through the forward gears he said that 3rd gear was gone and i had a possible tc failier. i spent $2500 to sell it other wise i would have bought a bts. i did a little beefing up. hd sprags, hd tc and a shift kit.
Old Sep 22, 2011 | 10:27 AM
fordpride's Avatar
fordpride
I have a buddy that hade a warped case in a 97 2wd his truck would shift to 2nd and that was it. If the case was warped then it's warped it wouldnt straighten it self outand the warp again
Old Sep 22, 2011 | 10:34 AM
Shaun lindmark
Originally Posted by fordpride
I have a buddy that has a warped case in a 97 2wd his truck would shift to 2nd and that was it. If the case was warped then it's warped it wouldnt straighten it self outand the warp again
I completely agree. You are saying that if it is warped it would have these problems all the time not on and off. It doesn't seem to be heat related either because its does both hot and cold.
Old Sep 22, 2011 | 10:43 AM
fordpride's Avatar
fordpride
Correct if it was warped at let's say 2nd then the fluid would just bypass the clutch pack and cause it not to shift.
My buddy's trans was rebuilt 3times in a week and it would do the same thing every time so they told him it has to be the case he found a place that's sells just a case for 120.00 shop built it again with the new case and all is good
Old Sep 22, 2011 | 10:50 AM
Shaun lindmark
That's good to know. I think your right and for example on the way over to his shop it was working perfect. It was completly up to temp and everthing. I just hope he calls me and says it was this stupid little thing. I almost **** when he said it could be the case. Figured I would ask some of you guys on here what you thought. Plus if he says it is the case then I might go to another shop and ask there opinion
Old Sep 22, 2011 | 10:54 AM
fordpride's Avatar
fordpride
I would but almost willing to bet that he will say it's a bad case
Old Sep 22, 2011 | 10:57 AM
Shaun lindmark
Hope not. Is there anyway to rule it out ?
Old Sep 22, 2011 | 11:35 AM
fordpride's Avatar
fordpride
Not that i know of. I wouldn't worrie about it. I don't think you have a case problem
Old Sep 22, 2011 | 11:54 AM
Shaun lindmark
Thanks man.
Old Sep 22, 2011 | 12:00 PM
fordpride's Avatar
fordpride
If you do end up needing a build I would get the parts from racer x
Old Sep 22, 2011 | 12:03 PM
Shaun lindmark
That's big money though right ?, also i dont see how it could be warped because i have never seen the trans temp over 175 isnt heat the only reason it will warp
Old Sep 22, 2011 | 12:13 PM
rideracelivemx7's Avatar
rideracelivemx7
its not so much looking gears that's the Issue, its the tc not locking first thing in the morning. Shifts threw all the gears fine but you have to drive for 5 mins It seems and make 3 to 5 are then Its fine. Diving it the other night it just dropped everything but 1st and 2nd at full temp. Let it sit for a hour, drove It home in second, put it to the wood and it all came back.
Old Sep 22, 2011 | 12:32 PM
DIYMechanic
The way I understand it, the PCM will not let the TC lock up until things start to warm up. It lets the TC slip to start to build some heat.
Unless I am misunderstanding what you're trying to say, that is... I had a hard time following what you posted. I take it you two know each other and you're talking about his truck?
