C-6 will not up-shift
Old Apr 2, 2007 | 11:43 AM
Huntersbo's Avatar
Huntersbo
The C-6 in my 1982 Ford Pickup 4x2 (2 wheel drive) with a 351 windsor will not up shift. I have to drop the gear lever from D to 2 to up shift into second and I do not have third. It shifted fine a year ago and it has sat un-driven since then. The trans cooler is still hooked up to the tranny; is there any externay vacume device that works with the valve body? The kickdown is hooked up, but I am consiering the possibility that it is not hooked up correctly.
Old Apr 2, 2007 | 02:48 PM
WarWagon's Avatar
WarWagon
Check the vacuum modulator. See if it is hooked up or defective.
Old Apr 3, 2007 | 12:56 PM
Huntersbo's Avatar
Huntersbo
Thanks; I found a metal vacume line on top of the bell-housing, I hooked it up to manafold vacume and it shifts agian.
nothercrash
Mar 5, 2024 07:51 PM
emeraldcoupe
Ford Truck Parts for Sale
Aug 13, 2014 05:58 PM
CalebJns
Apr 30, 2010 01:27 PM
562dragnhra
Nov 10, 2009 06:23 AM
