New to forum
Old Sep 9, 2010 | 11:04 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
They are manual to lock, but you have auto vacuum actuators built in, it's a fail safe that you can get them into 4X4 if needed, some of us opted to replace the factory ESOF (Electronic Shift on the Fly) as they are called for true manual locking hubs.
If you can manually turn them then they are working,
There is plenty of reading when it comes to the hubs.
Here is a service link if you plan on keeping them factory, they also have pictures of the hubs face for position reference.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Sep 9, 2010 | 11:33 AM
GlenC's Avatar
GlenC
Thanks. So if I understand this correctly I can either manually engage the hubs or just allow the vacuum system to engage them for me? I prefer the manual myself. I also prefer the 4x4 shifter in the floor instead of the push button or selector switch..lol
Old Sep 9, 2010 | 11:51 AM
howler4x4's Avatar
howler4x4
Welcome to FTE !
Back to your knock... Check for leaks at the heads to exhaust manifolds - a minor leak can go away as the manifold expands as it heats up. Look for broken manifold bolts and black discoloration (sign of leakage). Use a 3' length of 1" hose as a stethescope.
I think there were some variations, but most hubs are auto or locked. Turn CCW for auto, CW for lock. To test, turn to lock, then try to turn the front axle shafts. They should be locked (or lock as you turn). Then turn to auto, the shafts should be free. Leave in the auto setting.
4WD can take some movement before it engages, follow the owner's manual exactly.
X-70STANG-F150
1997 - 2003 F150
Oct 7, 2015 08:31 PM
clemarr
2009 - 2014 F150
16
Jul 27, 2012 08:28 PM
Agent99
May 16, 2012 04:46 AM
Diana33
1983 - 2012 Ranger & B-Series
Apr 22, 2012 08:16 PM
calguy
21
Dec 6, 2011 07:19 PM
