SICK 2000 350 FORD
Old Sep 6, 2010 | 12:00 PM
big-fordtractor's Avatar
big-fordtractor
SICK 2000 350 FORD
I HAVE A GREAT TRUCK THAT USE ALL THE TIME ON MY FARM BUT THE OTHER DAY IT LEFT ME STANDING ON THE SIDE OF THE ROAD WITH MY TRAILER IN THE ROAD. MY QUESTION IS MY SUPPER CHIP DECODER SAY THE (ICP NOT CONTROLLABLE) THE TRUCK RUNNS ALRIGHT WITH NO TRAILER BUT YOU PUT A VERY LIGHT LOAD ON IT AND ABOUT 30 MPH IS IT AND IT GOES DOWN TO NOTHING AND STARTS RUNNING VERY ROUGH WITH A LIGHT WHITE SMOKE WHILLE IT IS TRYING TO PULL. ANY HELP
Old Sep 6, 2010 | 12:20 PM
Racerguy's Avatar
Racerguy
Welcome to FTE
I've moved your question to a more appropriate forum for you.
Good luck with it.
Old Sep 6, 2010 | 12:26 PM
Izzy351's Avatar
Izzy351
Any other codes? Could just be a bad ICP sensor or IPR. Try disconnecting the ICP sensor (it's the one on the front-driver's side, next to the fuel filter bowl). If it improves, that's your problem. If not, could be IPR, or a few other things. Need more details & troubleshooting to tell for sure. But with just that code, I'd start there.
Also, how are your filters? Clean/relatively new? Could be a fueling issue (filter/dieing pump).
Old Sep 6, 2010 | 01:03 PM
big-fordtractor
Put new filters in first thing no other codes. But why does it not have any power when pulling and has power when not pulling a trailer? Also what does the ICP sensor do ?
Thanks
Old Sep 6, 2010 | 01:04 PM
big-fordtractor
Originally Posted by Racerguy
Welcome to FTE
Good luck with it.
Thanks new to this were did you put it I am done getting help.
Old Sep 6, 2010 | 02:49 PM
HD Rider's Avatar
HD Rider
He moved your question to the 99-03 7.3 Powerstroke Forum.
Did you try unplugging the IPC like Izzy said? It senses Injection Control Pressure. If there is oil in the plug or leaking from the plug it is bad and needs to be changed. Also if the engine starts and runs better with it unplugged, it is bad and must be changed. You can not drive the truck with it unplugged. That is the high pressure oil that fires your injectors. There is also an IPR (Injection Pressure Regulator).
With it falling down under load it could also be a fuel problem. I see you changed the filter with no change but there are some fine screens inside the fuel tank that can become clogged and cause problems. You need to check fuel pressure at the fuel filter. If it is low, those screens should be checked and or removed, commonly called the Hutch mod.
Here is a bunch of helpfull information. Roadside Help Network - Guides, Maintenance & Mods
Old Sep 6, 2010 | 03:59 PM
big-fordtractor
Unpluged the ICP also took it out dry inside and out is there any hope seams to have a good fuel stream. Also thanks for all the help.
Old Sep 6, 2010 | 04:20 PM
Izzy351's Avatar
Izzy351
You need to check your fuel pressure under load. Need a fuel pressue gauge you can see from the driver's seat. Here's what mine looks like:
Old Sep 6, 2010 | 06:38 PM
PaysonPSD's Avatar
PaysonPSD
Is there oil in the exhaust pipe?
Old Sep 6, 2010 | 07:36 PM
big-fordtractor
No dry just shut
Old Sep 6, 2010 | 08:12 PM
zx250's Avatar
zx250
Of the next Riffraff East
I think you should first make sure you have full, clean oil and clean fuel filter. Check the nut on the back of your IPR and make sure it's tight. If all that checks good, the the ICP would be the next choice.
Old Sep 6, 2010 | 08:15 PM
F350-6's Avatar
F350-6
Thanks
I'd guess your problem is plugged screens in the mixing chamber (inside the fuel tank). You've got enough fuel to tool around empty, but really stand on it or pull a heavy load, and not enough fuel can get through to meet demand.
As Joe shows, an easy way to figure this out is just to plumb in a gauge to one of the ports on the fuel filter bowl and watch what your fuel pressure does when you mash the skinny pedal or pull a trailer.
Here's what they're supposed to look like
But more often they look like this when problems like yours show up.
To eliminate this problem, most of us drop the tank and just throw away the mixing chamber. Then add some type of inline filter to catch large junk between the tank and the pump to act in place of these screens, and you'll never have this issue again. Instructions on the DIY version of this are here Welcome to guzzle's In-tank Hutch Mod Web Page
We also sponsors that sell a pre-packaged kit with all the pieces you need if you hate shopping.
The P1211 ICP code is likely related to your Superchips. Pretty common code with a chip and tuner. I'd ignore it till you figure out the fuel.
Old Sep 8, 2010 | 10:05 AM
HD Rider's Avatar
HD Rider
Excellent post Chris. Tried to rep you but the rep police got me.
Old Sep 8, 2010 | 11:34 AM
clem1226's Avatar
clem1226
X2........
Old Sep 8, 2010 | 02:33 PM
Ponyboychris's Avatar
Ponyboychris
I got him! Yes, excellent post and a good reminder to do this mod.
Aufgeblassen
All Things Towing
21
Jul 14, 2014 05:39 PM
ETKMS
6.4L Power Stroke Diesel
Apr 15, 2012 05:28 AM
makomaker
21
Apr 3, 2010 03:22 PM
NoBite
All Things Towing
22
Sep 24, 2007 06:56 AM
BASSHUNTER
Dec 14, 2006 04:05 PM
