Want to install EOT , ECT ,EGT on a pillar pod. What is the best way to install the sensor for these. Use a T and keep the stock sensor there? If so where is the stock oil temp and water temp sensors.
the best way is the way that the installer finds. There is a thread about eot gauge install going already. you will find the parts listed there as well. I belive the thread was started by "Lewis Racing" the ect I would not split off of becase of were it is.
for coolant you may find it easer to go to the water jacket on the left side of the block.
the factory locations are
eot on oil cooler housing
ect on top of front cover
there is no egt from the factory.
My quadzilla commander standalone monitor had me splice into the OEM temp sender....it has worked flawlessly for 3 years now....no extra sending unit came with the kit for the coolant temp. Not the best alternative but like I said it has worked flawlessly for years
