88 f150 temp sensor not working?
Old Jan 18, 2004 | 08:06 AM
irishman200232's Avatar
irishman200232
just installed new temp sensor its not reading and tested it with
a test light and im not getting a juice, any ideas?
Old Jan 18, 2004 | 09:40 AM
99 ranger bob's Avatar
99 ranger bob
bad sensor it does happen!
Old Jan 18, 2004 | 09:49 AM
irishman200232
im not getting any juice from connector though, wasnt working so i replace it thinking it was sensor?
Old Jan 18, 2004 | 04:02 PM
EPNCSU2006's Avatar
EPNCSU2006
What connector, and what temp sensor? The one for the guage? I didn't know you were supposed to have voltage there. I'd check for continuity between the sender and the instrument cluster, or the sensor and the computer depending on which one it is.
Old Jan 18, 2004 | 09:17 PM
irishman200232
the coolant temp sensor, i thought it had current? how do i check for continuity on this?
Old Jan 19, 2004 | 11:12 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm assuming this is for the guage in the dash. Take a small screw or something and short the wire to ground. Go turn the key to run, and if the guage pegs to hot, then the wiring should be good (don't leave it on longer than necessary, you can damage the guage). The sender for the guage has one wire going to it, the sensor for the computer has two.
NBT22555
Jun 13, 2014 06:51 PM
Dutch13
6.4L Power Stroke Diesel
Feb 27, 2014 08:18 AM
thbowen
Nov 22, 2013 08:12 PM
moebdick
Oct 4, 2010 05:06 PM
amberamber
Nov 9, 2005 06:56 PM
