Sponsored by: Real Truck
I admit, I was wrong.
Old Sep 6, 2010 | 02:03 AM
  #31
exiled's Avatar
exiled
Originally Posted by redford
So, are you now using the new spark plug design?
I don't know about the new ones. In my wife's 04 f150i use Bosch and in the 07 mustang I use the Roush. In 3k miles I'll the plugs in the 2010 mustang and see what they are like. I plan on use Roush in there too. What's the new design?
Old Sep 7, 2010 | 06:46 AM
  #32
krewat's Avatar
krewat
FTE Leadership Emeritus
The "new design" is a single piece plug instead of the old two-piece that came apart when removing them.
Never heard of a "class action lawsuit" about this particular issue. Neither the first, where the 2-valve heads were blowing plugs, nor the last where the 3-valve heads wouldn't let go of them
One of the funniest things I came up with when I just searched for this was "No other Automobile manufacture has engines that blow spark plugs out of the head.".
Totally and completely untrue. We had a VW tech here in the V10 forum, captchas. He would routinely lambaste people who complained about Ford and said exactly that: No one else has problems.
Why? Because VW/Audi engines routinely ejected plugs and he had to fix them in the shop, countless times. If you look at the Timesert website, you will see insert kits for a bunch of different manufacturers, and generic kits that work on a wide range of engines. Why? Because not only mechanics and DIY'ers screw it up, but they do come loose even when they are factory installed.
I think Ford could have stepped up and taken care of a few more of the problem engines, especially the 2-valvers, but they did try to alleviate the problem at the factory level. Attached at the bottom of this post is the timeline for the 2-valve engines, gleaned from the NHTSA investigation into the 2-valvers blowing plugs.
That NHTSA investigation was stopped in it's tracks by a lawyer who lied about the safety issues. This lawyer started an investigation with something like 8 to 10 people, and when the NHTSA contacted those people, they got a different story. The NHTSA, once a lawyer lies, stops the investigation and refuses to ever look into it again.
Blame that lawyer, not the NHTSA.
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Old Sep 7, 2010 | 08:07 AM
  #33
Bert56's Avatar
Bert56
Originally Posted by sammy77
Can we get back to talking about women.....??
...I'm with Sammy
PK
Old Sep 7, 2010 | 11:14 AM
  #34
thomasnchy's Avatar
thomasnchy
I have three trucks that I've installed Champions in (pn-7989). So far no issues, but it's far too soon to say. I've also taken to monitoring the hour meters instead of the miles between plug changes, which I should have done in the first place.
Old Sep 7, 2010 | 02:27 PM
  #35
89CrewCab's Avatar
89CrewCab
I'm not happy with "potential" issue either.
Check out these guys:
Brokensparkplug.com --> for 3v.
Blownoutsparkplug.com --> for 2v.
Give them a call or email. They are more willing to discuss your situation.
Old Sep 7, 2010 | 03:06 PM
  #36
redford's Avatar
redford
My old Chevy LUV used to blow plugs out with alarming regularity. Since I was poor (as demonstrated by driving a POS Chevy LUV) I used to super glue the boot on to the plug. It would catch the plug so I could screw it back in, also using super glue.
No women were involved.
Old Sep 7, 2010 | 04:41 PM
  #37
ken kenmnedy's Avatar
ken kenmnedy
I have done plugs in both kinds if you do the right pross...2v overnight cold...3v HOT back to front 1hr and change ...each time
FordCamping
Modular V10 (6.8l)
28
Feb 27, 2014 09:45 AM
D-Rock
2004 - 2008 F150
Jan 26, 2011 01:43 PM
D-Rock
Jan 9, 2011 06:26 PM
Inabind
2004 - 2008 F150
Aug 6, 2010 09:37 AM
