Carb Identification
Old Sep 4, 2010 | 04:09 PM
jglee's Avatar
jglee
Carb Identification
I just picked up a '66 F-100 this week and the carb is leaking fuel out of a diaphragm. It's a Motorcraft on a 390 but I'm new to this and have no idea which one. There is no tag on the carb and the only stamping on it is U34. Forum and 'net searches have come up blank. Can someone point me in the right direction?
Also, should I just get the diaphragm part or an entire repair kit? Thanks in advance!
Old Sep 4, 2010 | 04:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
2V or 4V carburetor? Does the carb have an electric solenoid valve used with the throttle linkage?
Is the carburetor a Motorcraft or an Auto-Lite?
No 390's in F100/350's until 1968. 1965/67 F100/350: The only available V8 was the 352 2V.
Old Sep 4, 2010 | 05:17 PM
jglee's Avatar
jglee
It's a 2V. This isn't the original motor. Sorry for the confusion. I believe it does have the solenoid onthe opposite side from the linkage. It's got Motorcraft stamped into the metal on top. The only other ID mark I've found (it's pretty nasty right now) is a sticker that appears to say remanufactured and 1995.
Old Sep 4, 2010 | 05:24 PM
jglee's Avatar
jglee
BTW, I've got some pictures but apparently you have to have a certain number of posts before you can upload them?
Old Sep 4, 2010 | 07:30 PM
Bill W's Avatar
Bill W
Your carb should have some numbers/letters stamped on the base plate... like C5TB-F
use these numbers and this forum to find out the info your after
>>>ford 2100<<<
location of stamping is below.
Old Sep 4, 2010 | 07:59 PM
jglee's Avatar
jglee
Thanks alot, Bill. Let me go knock some more crud and varnish off and see what I can find. :-)
Old Sep 4, 2010 | 11:07 PM
NumberDummy
An ID engineering number marked on a part found on a carburetor is for that particular part only. It is not the carburetor ID tag number.
The ID tag was tri-angular shaped, bolted to the airhorn. Do not be surprised if it's missing.
The carburetor kit for the 2V Auto-Lite/Motorcraft carb is the same from 1962 thru 1974 for everything: Passenger Car//F100/350//Bronco//Econoline.
D4AZ9A586A (replaced C2AZ9A586B) .. Carburetor Kit / Motorcraft CT499D (replaced Auto-Lite CT499B).
From 1975 thru 1979, there are...at least SIX different carburetor kits!
If fuel is leaking from the square plate (held on by four bolts) found on the front of the carb, behind that plate is the accelerator pump diaphram, coil spring and check valve.
There is one acc. pump diaphram for 1962/74: C4AZ9B559A-Motorcraft CM463
Two possibles were used 1975/79, the one above...or D5AZ9B559A-Motorcraft CM2092
There is one check valve 1962/79: C4AZ9576A-Motorcraft CM825
These parts also came in the carb kits.
1980 and later. There is no way to look up carburetors/kits in the parts catalogs, as there are no application charts for them.
The vehicles specific Calibration Code (C/C) number must be known (there are 800 (!) just for 1980/89).
Then when the specific C/C is looked up, it gives the parts list number where carb/carb parts, emission parts, computers and other fall-der-all are listed.
Old Sep 4, 2010 | 11:56 PM
Bill W's Avatar
Bill W
Huh? Bill, the same number stamped on the carb base plate is the same number on the ID tag.
Old Sep 5, 2010 | 12:19 AM
NumberDummy
I'm not gonna argue...I stand by what I said.
When the OP comes back with the stamped number, you can give him the carb kit part number.
If the number is 1962/74 related, there's only one carb kit...if it's 1975 and later, lotsa luck.
Old Sep 5, 2010 | 08:20 AM
jglee's Avatar
jglee
That's exactly where it's coming from.
I'm wondering if this thing has just been put together with whatever parts they had laying around. You wouldn't believe what they did to the brake system.
Anyway, the only thing I can find stamped in te area Bill W. showed on the base plate is either 20CA, 26CA, or 26CA. There's a mark right through the second character and nobody in the house could agree on what it was.
69-er
May 3, 2017 08:30 AM
maddogjohnson
Mar 11, 2017 10:28 AM
PapaBearYuma
Mar 5, 2017 10:44 AM
Paso1
Mar 9, 2015 12:22 PM
F250racer
Large Truck
Nov 10, 2010 12:14 AM
