Clutch pedal spring
Old Sep 4, 2010 | 03:18 PM
47ky49's Avatar
47ky49
Clutch pedal spring
Help! I bought a 50 Ford F1 "project". In trying to adjust the clutch pedal I realized the return spring was not attached. After searching through the "extra" parts that came with it I found the spring. I have found where the spring attaches at the clutch and where it goes through the crossmember but where does the other end attach?
Old Sep 4, 2010 | 04:20 PM
Julies Cool F1's Avatar
Julies Cool F1
HI and welcome to FTE!
I'm a little confused with your wording - it sounds like you answered your own question.
But just to reiterate, one end of the spring attaches to the pin (7533) running through the end of the release arm clevis rod (7521) on the clutch pedal release arm (7503) and the other end attaches to the transmission cross memember to the right of the pedal assy bracket.
Just FYI, the brake pedal spring attaches to the pedal and a tab bolted the flywheel housing (front half of the "bell housing") just below the clutch release shaft. The brake pedal spring is longer (so if yor spring is too long to attach to the cross member it may be the brake pedal spring.)
Picture:
Name:  Clutch Bonus Built.jpg
Old Sep 4, 2010 | 04:48 PM
jb50F1's Avatar
jb50F1
I think this is a picture of the connection "at the other end"on a 50 F1
Old Sep 4, 2010 | 04:50 PM
jb50F1's Avatar
jb50F1
Ooops, trying again. You got the picture to the frame not the clutch - my eyes are getting bad...
Old Sep 4, 2010 | 04:56 PM
Julies Cool F1
Yep, you can just make out the spring on the head of the pin as it goes through the end of the rod in that pic!
Old Sep 5, 2010 | 11:00 AM
47ky49's Avatar
47ky49
Thanks for all the info. This solved my problem! I'm sure I'll have other questions. I previously owned a 54 pickup but there are differences.
AJHEATING
Apr 15, 2022 10:29 AM
abe
Nov 2, 2013 10:56 PM
Mikejones16
Sep 9, 2013 06:04 PM
bailegb
May 19, 2010 06:02 PM
mackdog
Apr 26, 2010 03:59 PM
