Flasher Module Location
Old Sep 2, 2010 | 06:25 PM
MikeyG123's Avatar
MikeyG123
Hi Everyone,
I'm having issues with my turn signal not functioning properly. Sometimes they flash, and sometimes they just stay lit up. I checked all of the bulbs and they seem to be fine, so my next guess is that it may be the flasher module. The only problem is that I'm unable to locate it. Could someone please tell me where the flasher module is located on a 2003 Expy?
Thanks for any help you can offer.
Old Sep 5, 2010 | 12:32 PM
slow93's Avatar
slow93
Its behind the dash. You have to remove the lower cover and you can see it behind the dash panel on the drivers side mounted by 2 bolts. It is in a housing and has a cover over it. It is a pain to get at.
Old Sep 6, 2010 | 02:23 PM
MikeyG123's Avatar
MikeyG123
Thanks Slow. Is the lower cover pretty simple to remove, or are there other components that need to come off first? Thanks again.
Old Sep 6, 2010 | 10:27 PM
slow93's Avatar
slow93
No not really just some inspector gadget arms. You will see it when you take off the lower panel facing the firewall on the dash frame. Let me know if you have any problems as I am putting LEDs on my truck and will be having to swap flashers.
Old Sep 8, 2010 | 06:24 PM
MikeyG123's Avatar
MikeyG123
Thanks Slow. I've got the panel off and I see the housing. Do I need to remove the 2 bolts, or can I just pop the cover off of it and replace the module?
Old Sep 8, 2010 | 08:39 PM
MikeyG123's Avatar
MikeyG123
Slow, no need to respond to my last post. I actually was able to pop the top off and replace the module. That did the trick. Thanks so much for all of your help, and good luck with your LED's.
YooperUno
Oct 1, 2016 03:57 PM
weden5008
2009 - 2014 F150
May 19, 2016 03:24 AM
gpeade
2004 - 2008 F150
Dec 12, 2015 09:20 AM
Rusty Ford
Nov 12, 2015 10:32 PM
Bullnose Bob
Feb 9, 2015 08:52 PM
