Sponsored by: Real Truck
MAF question
Old Sep 2, 2010 | 12:13 AM
sspikaroo's Avatar
sspikaroo
MAF question
Does anyone know what the typical MAF sensor reading would be in lb/m at wide open throttle on flat ground in a 1999 F250 superduty with the 6.8L 2V V10? I am seeing around 24 lb/m and am wondering if the MAF sensor is accurate.
Thanks in advance.
Old Sep 2, 2010 | 07:58 AM
Johnny Langton's Avatar
Johnny Langton
At what RPM? 24lbs/min is about right for higher RPM,somewhere near peak HP.
JL
Old Sep 2, 2010 | 06:25 PM
sspikaroo's Avatar
sspikaroo
Reading taken during test run for timing 0 to 60 mph with the go pedal all the way to the floor. RPM seems to max around 5000 rpm before shifting. Truck is completely stock. Saw MAF readings in the 24 lb/m range with possible brief peaks up to 25 lb/m.
The reason I ask is the truck seems like it might be a little sluggish in that test. It consistently takes it about 13 seconds to reach 60 mph. I get the impression from the stuff I've seen on the net that it should perhaps be able to do it in around 10 sec.
Other than that possible issue, I can't complain. The engine runs and idles smoothly. Truck is 1999 F250 Superduty crew cab long box with 4x4 and 4R100 automatic and 6.8 L V10.
dsladdict
Feb 14, 2017 07:57 PM
opcom
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 3, 2017 08:19 PM
Shaneb75
Jan 3, 2016 06:07 PM
chance.5e
Sep 28, 2015 09:10 PM
fderflinger
Aug 21, 2007 06:38 AM
