abs light
Old Sep 2, 2010 | 12:13 AM
Sicko's Avatar
Sicko
abs light
Okay guys I need some help.. My 2008 super crew has been throwing a abs light here and there but it only seems to happen when I am in cruise control. The truck has 42000 miles on it and front pads and rotors were changed 2000 mi ago. this is really starting to annoy me cause its only the light and when I brake I have not noticed the abs really to be actuating. any help would be appreciated,
Pj
Old Sep 2, 2010 | 06:01 AM
kevincw's Avatar
kevincw
It sounds to me like a wheel sensor going bad. Some others will chime in latter and may have a better idea.
Old Sep 2, 2010 | 08:34 AM
benky's Avatar
benky
My ABS light did this for about a month or so and then stayed on continuiously. Turns out I had freyed wires leading to my speed sensor. Check the wires that come out of the cab side of the rear diff. Track them all the way back to the driver side rear to make sure connections or wires didn't come loose.
Mine happened to melt due to some exhaust work that was poorly done. Going back today to have them re-position where the pipe crosses over the rear diff.
Good luck!
Old Sep 2, 2010 | 09:59 PM
Sicko's Avatar
Sicko
k thanks for the replies I will check both in the morning.
Old Sep 14, 2010 | 07:29 PM
baitmaster's Avatar
baitmaster
Benky, I had the same prob. Had crawled all over under the truck looking for bad wire. Bought a code reader, and it said, "bad wire". Looked again, and found wire on top of punkin melted. My fault, had a big load of dirt in the truck, and guess it was squatting too much.
Old Sep 14, 2010 | 08:03 PM
Sako 75's Avatar
Sako 75
Codes?????????
Beastlyforddude
Feb 16, 2011 01:54 PM
Loopy
Jan 13, 2011 08:40 PM
cratemotor
1983 - 2012 Ranger & B-Series
17
Dec 3, 2007 12:23 PM
bronco5.8
1978 - 1996 Big Bronco
Jun 28, 2005 09:57 AM
bronco5.8
Aug 13, 2004 10:27 AM
