Sponsored by: Real Truck
ABS Problem
Old Jan 13, 2011 | 07:59 PM
Loopy's Avatar
Loopy
ABS Problem
My ABS light recently came on while driving about 35 mph down the road. It has stayed on for about 2 weeks. I haven't really noticed any braking problems until the other day. When I started the truck the ABS light did not come on as it normally has for the 2 weeks. As the light was out I slowed down approaching a stop sign. The ABS engaged as the truck came to a complete stop. This happened during a non slippery situation. As I pulled away the ABS light came back on and it did not have the same symptom as I came to further stops. The problem only has occured a couple times when the ABS light is off. Any thoughts? I haven't checked for a code yet.
Old Jan 13, 2011 | 08:16 PM
gearloose1's Avatar
gearloose1
Reset the computers... It can be caused by salt.. .circuit shorting iwth ice snow.
Old Jan 13, 2011 | 08:40 PM
Wilber15's Avatar
Wilber15
Speed sensor is problably loosing signal. Get the abs module scanned for codes. Could be rust under the front sensors causing excessive air gap between sensor and tone ring, or a bad rear diff sensor.
MotoStrada
Jan 2, 2015 08:15 PM
michigan66
1983 - 2012 Ranger & B-Series
Jul 18, 2011 10:17 AM
Scndsin
Escape & Escape Hybrid
13
Apr 12, 2011 06:50 AM
cratemotor
17
Dec 3, 2007 12:23 PM
bronco5.8
Aug 13, 2004 10:27 AM
