MAF and Throttle body sizing
Old Sep 2, 2010 | 12:09 AM
shermy2296's Avatar
shermy2296
I have a 54 F100 that I've rodded. I put a 91 Lincoln LSC 5.0 HO into it and converted to mass air. I put GT40P heads and Gt40 intake onto it from a 98 Explorer. I put an after market 65mm throttle body(to match the 65mm Explorer throttle body) and long tube headers. I'm using a A9P PCM from a 91 Mustang GT. I have driveability problems at cruise and light load. If I open the throttle , it comes to life with decent power. My question is, should the MAF be larger(or match) than the throttle body(I'm using a MAF from a stock 91 GT which had a 55mm throttle body)? The motor, heads, intake, and throttle body are roughly now equal to a 93 cobra except for the PCM and MAF. Any advice on this would be nice.
Thanks,
Mike
NH
Old Sep 2, 2010 | 02:47 PM
lew52's Avatar
lew52
If your using a 65mm TB i would use a 75mm meter.....Lew
Old Sep 2, 2010 | 09:43 PM
BlueOvalRage's Avatar
BlueOvalRage
I agree. The ID of the MAF should be equal to or preferably larger than the ID of the throttle body. A MAF that is smaller than the throttle body will not, however, cause driveability problems. It will only reduce airflow and full throttle performance. What size fuel injectors are you running? If you try to run anything besides a 19 lb. injector with that ECM and MAF combo you will have problems. Another place to look is the throttle position sensor. If it's an older sensor and the signal is getting flakey, it can cause surging and rough running also. There are several other things that can cause your issue, but making sure you're running the proper injector size and that the TPS is working right are the best places to start.
nighthawk285
24
Jan 9, 2017 01:07 PM
Ian Pendergast
32
Mar 15, 2016 12:44 PM
Glaser67
Jan 31, 2016 12:44 PM
scott9320
Jan 11, 2007 12:49 PM
cow_rancher
Aug 15, 2001 06:42 PM
