camshafts
Old Sep 2, 2010 | 08:19 PM
walt cook's Avatar
walt cook
Post camshafts
hey guys i am cuurently rebuilding a 360 ,and i need some input on a cam that give me a little more bottom end with more mileage .does anyone have any info . thanks
Old Sep 3, 2010 | 01:40 PM
85e150's Avatar
85e150
You are in the wrong forum. Check out the FE forums.
As far as a 360, if you are just starting your rebuild, consider turning it into a 390. You can more easily raise the compression, and you'll gain lots of power for the same or, if you're careful and lucky, better mpg.
A cam change for a 360--it's already a "low end" only motor, for the most part, and fuel economy isn't going to improve much with low compression and the existing gearing and fuel system.
