Power Port
Old Sep 1, 2010 | 09:14 PM
1_BIGMOFO's Avatar
1_BIGMOFO
Power Port
Can someone please tell me where the power port on the upper dash's fuse is located? I blew the fuse last winter and its been driving me crazy since.. Also, when using a plow light which port should I be using?
I tried the "cigar lighter" fuse and that must be for the lighter on the lower panel.
Any help is appreciated. Thank you
Old Sep 2, 2010 | 09:01 AM
1_BIGMOFO's Avatar
1_BIGMOFO
bump..... anyone??? please...
Old Sep 2, 2010 | 10:21 AM
dchamberlain's Avatar
dchamberlain
#4 in the Central Junction Box under the drivers side dash.
For future reference, you can download your Owner's Manual here...
https://www.flmowner.com/servlet/Con...ionalEventPage
Old Sep 2, 2010 | 11:14 AM
1_BIGMOFO's Avatar
1_BIGMOFO
thanks for the help..I looked in the owners manual and couldnt find it. All I could find was "cigar lighter". What is it actually called in the manual?
Old Sep 2, 2010 | 11:23 AM
dchamberlain
Page 196 in mine (downloaded).
4 20A* Power point - instrument panel
Old Sep 2, 2010 | 12:04 PM
1_BIGMOFO's Avatar
1_BIGMOFO
I will check it out, thanks a ton!!
Old Sep 2, 2010 | 07:09 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here's a picture.
Old Sep 7, 2010 | 04:29 PM
1_BIGMOFO's Avatar
1_BIGMOFO
That fuse is good, is there any way I fried the actual port in the dash?
Old Sep 7, 2010 | 05:28 PM
dchamberlain
It's possible. Or the wire came loose.
Did you test the fuse with a meter or test light?
Old Sep 8, 2010 | 06:09 PM
1_BIGMOFO's Avatar
1_BIGMOFO
I tested the fuse with a test light and it came back good on both sides. I took the dash apart and removed the power port and it appears to be slightly melted on the inside. I am going to stop at our local dealer and pick up a new one.. I must have damaged it with my plow light last year.
Just out of curiousity which plug should I be using for a plow light, the top power port or the lower cigar lighter? Thank you
Old Sep 8, 2010 | 06:12 PM
dchamberlain
The Owner's manual says to use the power point for any power accessories.
It seems odd that the power point would actually melt before blowing the fuse. There must've been a pretty good load on it.
You might want to think about hard wiring your plow lights directly off of the battery with an inline fuse.
Old Sep 8, 2010 | 06:17 PM
1_BIGMOFO's Avatar
1_BIGMOFO
I think the actual plow light I was using must have a short in it. I have had it for a couple years and it did the same thing to my last truck. I tried re-wiring the light with a new cord several times and nothing works.. I installed strobes in the truck this summer and I plan to use them in addition to a new LED plow roof top light so this dosent happen again.
I am going to the dealer to order a new one tomorrow and I will keep this thread updated if it solves the problem.
Thank you and I appreciate your help.
rews2
16
Jun 30, 2014 06:45 PM
Icicle
May 30, 2014 02:37 PM
TheRifleman
Electrical Systems/Wiring
Jan 20, 2014 01:34 AM
Jaime74656
Jul 22, 2011 09:20 AM
Kincaids f-350
Sep 18, 2010 11:25 PM
