Auxiliary Power Port
Anyone have tips for an auxiliary power port that isn't working? The cigarette lighter works, but the power port doesn't, pretty sure they are on the same fuse. I know these things can be temperamental, so I've tried moving the device around inside the port to get a better connection to no avail. The same device (gps) works in the lighter port.
I need to get under dash and check the wiring (I really need to learn how to use a voltmeter) and make sure it's connected okay. Any tips would be helpful.
In 1996 they had separate fuses for the cig lighter and the power port, both in the underdash fuse box. In 1999 they had separate fuses also, the cig lighter fuse in the underdash fuse box and the power port fuse in the underhood fuse box. Sorry, I do not have a 1997 diagram. But it looks like it probably does have a separate fuse.
Now when you get to 2000 it all changes. Very good diagrams, and they are factory style, with connector views, component views, lots of accessory diagrams, entertainment system diagrams, module diagrams, power distribution, most everything. The only thing wrong with these diagrams is some of them are missing(seems like a dead link). But most everything is there.
I would be very surprised if you found any wiring diagram info on the power port in the 97 diagrams at Autozone. But you can't fault them too much, at least they have something out there and they do not charge for it.
dustys7.3psd
17
01-09-2010 11:35 AM
