Gauge ranges
Old Sep 1, 2010 | 09:01 PM
FLATTIE's Avatar
FLATTIE
Gauge ranges
I might have an opportunity to buy a boost, trans temp, and EGT gauge direct from a name brand company through work. But I do not the ranges to ask for. I have a relativley stock 97. I know the boost gauge top limit should be scaled no higher than 30 psi, but what should the high range be for the trans temp and EGT be?
Old Sep 1, 2010 | 09:27 PM
F350-6's Avatar
F350-6
Typically you start to worry about the tranny temps around 200 deg, so depending on what gauges you look at, 250 - 300 as a top range min. Pyro worry zone is around 1250, but depending on tunes and mods, short runs up around 1400 are not unheard of.
Old Sep 1, 2010 | 09:32 PM
FLATTIE's Avatar
FLATTIE
Thank you for the quick reply sir.
EC
Old Sep 1, 2010 | 11:05 PM
jchosler's Avatar
jchosler
I would get the boost gauge that reads higher than 30, It's not uncommon to see those numbers with the proper mods. I would get a pyro that reads at least 1600 also
jbodin18
Jul 17, 2011 10:28 AM
Livn-lg
Jun 23, 2011 12:10 AM
chrison600
Apr 29, 2011 04:10 PM
north2south006
Mar 1, 2011 09:09 AM
ryanben
Jul 20, 2003 06:59 AM
