How much smoke.
Old Sep 2, 2010 | 06:04 AM
NorthernDiesel's Avatar
NorthernDiesel
The screw under the inspection cover increases fuel delivery, whats the difference with that screw you're moving in the vid?
Old Sep 2, 2010 | 08:49 AM
johnboggs21's Avatar
johnboggs21
the screw in the video increases fueling at low rpms.......its supposed to make the turbo spool faster
Old Sep 2, 2010 | 09:32 AM
tjc transport's Avatar
tjc transport
i ain't rite
black smoke out of the pipe has nothing to do with exhaust temps.
if the truck is burning the fuel properly, it will not smoke.
but the exhaust temps can still be dangerously high. that is why you need to put a pyrometer on before messing with the fuel delivery rates.
my 02 will give a healthy puff of smoke on takeoff with the fuel turned up to 140hp full race tune, and then burn super clean.
but it will also push the exhaust temp to over 1600º if i stay in it.
my 88 is set for a slight puff on takeoff, then burns clean through the rpm range. it tops out at 1100º pulling hills, and runs normally at around 750º
Old Sep 2, 2010 | 10:12 AM
joe f350's Avatar
joe f350
YouTube - little burn out
Old Sep 2, 2010 | 12:58 PM
10 sec brutus's Avatar
10 sec brutus
Am i getting this right?.......Allan screw behind the triangle cover on left hand side of pump increases fuel volume to injectors....... Allen screw @ back of pump increases fuel pressure.............so what function does the adjustment screw have that is in the video?, i realise you guys say it spools the turbo faster @ low RPM but what is the difference between this screw & the other two?
TIA.
Old Sep 2, 2010 | 09:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The internal screw adjusts the max fuel rate, how much fuel the IP can possibly pump with each stroke.
The screw in the video adjusts how aggressive the IP is about increasing the fuel rates at lower RPM's.
Hard to explain.
Not sure which screew you are talking about at the rear of the IP, I think you are talking about the govenor alignment shaft though.
Not good to mess with that one since it is what the linkages inside the govenor that control the fuel flow slide on to keep them in alignment and govenor springs where they are supposed to be
Old Sep 3, 2010 | 07:26 AM
10 sec brutus
I'm reffering to the 5/32 Allan screw that sits behind the fuel line feed into IP.
Fitting a boost gauge along with a pyrometer gauge today , this truck has gained some power since i turned up the IP , will also find out how much the turbo spools , tis a standard Garrett that came with the truck from factory.
Thanks.
Old Sep 3, 2010 | 09:15 PM
Dave Sponaugle
That sets the internal IP pressure.
The internal IP fuel pressure has a big effect on the timing.
For instance the timing advance solenoid closes off a vent passage, increasing the internal fuel pressure which in turn advances the timing.
As engine RPM increases, the fuel pump in the IP increases the internal fuel pressure, again advancing the timing.
The only thing that counter balances the timing advance caused by fuel pressure increase is the lever on the outside of the IP that runs from the throttle shaft down to the plunger on the bottom of the IP.
When that plunger gets pushed in when you press the throttle down and manually retards the timing.
Mechanical IP's are a balancing act.
Get to far out of balance, you fall down.
Old Sep 4, 2010 | 12:08 PM
10 sec brutus
Ok , this is what i got now the boost/pyro gauges installed , no hills & truck empty.........
Idle , 750 rpm...200* egt/.5 psi boost
1500 rpm........ 400* egt/ 2 psi boost.
2000 rpm.........600* egt/ 4.5 psi boost
2500 rpm.........800* egt/ 8 psi boost
3000 rpm.........800* egt/ 14 psi boost
No smoke on hard acceleration or anytime , only smoke is when floored from lights , this smoke only lasts a second or two , considering i don't use this truck on gradiants or pulling loads maybe i can adjust IP another 1/4 turn? , to be honest it runs fine as it is.
These readings were with foot to the floor from standing start.........boost gauge is plumbed into snail hat , pyro is installed into drivers side down pipe , wastegate was disconnected for this test.
Old Sep 4, 2010 | 10:43 PM
Dave Sponaugle
Looks like I would block off the waste gate port and run it like it is.
I am going to guess that 1/4 turn will be to much.
One thing to remember, do not bottom the internal fuel screw out.
If you do, it might be OK, or it might schear off the IP drive shaft.
What makes the difference is how much injection pressure builds before the head lines up with an injection line port.
Not worth the risk since the IP core value will be nothing with a scheared drive shaft.
kelwar
6.4L Power Stroke Diesel
Apr 20, 2013 06:57 AM
4x4countryboy
22
Oct 13, 2011 08:58 PM
4x4countryboy
Oct 11, 2011 10:20 PM
eatont9999
Aug 4, 2011 04:51 PM
kevinarnold021692
Aug 26, 2010 09:13 PM
