truck is running rough and shaking, not running on all cylinders? and shifting hard
I have a 201 F350 7.3L V8 4x4 crew cab with 159,*** miles
Ok so it all started 2 days ago, went out to start the truck it started loped bad and shut down, I got it started after about 4 times by holding my foot on the gas pedal started up, loped bad for about 5 seconds then smoothed right out. Service Engine Soon light came on and is still on, and is the only light thats on. When this happened I figured right away that I had gotten the mixture of "black diesel" (used oil that has been filtered) to regular pump diesel to strong, so since it was down a 1/4 tank I took it right to the pump and filled up and dumped in a can of seafoam.
It ran OK but not great, but I figured it just needed to work itself out, so after driving it more that day I put in another 1/4 tank of diesel. ran alot better than.
Than this morning I got in the truck and started it up and it feels like it has very little power, I drove it into town filled it up with another 1/4 tank or more of diesel, dumped in B12-chemtool ( I also run Diesel Kleene with every tank) then I drove it down the main street and from 38-45mph it shakes like all h*ll's about to break loose! SO i went to autozone, bought a new fuel filter and it made little to no difference (also hooked it up to their scanner and pulled no codes). Also it revs up high (I know diesels rev high but this is higher than normal) and then feels like it slams into the next gear, and the overdrive button is on (its NOT lit up) and I even tried turning it off to see how it did and no difference.
I have had no problems with black diesel before today, engine has been running smoother than ever since I started the black diesel, now I am worried that I have really screwed something up and I have been off work (not by choice) for 4 weeks so don't have alota money to "experiment" with.
ANY help would be GREATLY appreciated!
Thank you in advance
sounds like one of the plugs in the valve cover has come lose..
https://www.ford-trucks.com/forums/8...ck-shakes.html
Sounds to me like you have a uvhc disconnected when your trucks cold start it up and run it for 30 seconds then check which side exhaust manifold is not very hot, that side is the one that is dis connected, you will need to remove that side valve cover and re connect it, search the 50 cent mod as that will prevent future occurrences!
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
Jim & fat Monty
50 cent mod - Ford Truck Enthusiasts Forums
7.3 Diesel Powerstroke misfire runs rough code P1316 injector wire harness connection - YouTube
I have a 97 250 with the 7.3 powerstroke. T have had problems with the glow plug injector wiring harnesss if you unplug them you should be able to see if they are the problem. as far as taking off the valve covers the drivers side is a breeze but the other side is a bit more of a chore it took me about 6 or 7 hours. Hope this helps
As a newbie I hate to step on toes, but as I got ready to take off my valve covers this afternoon for the almost exact scenario posted above, something told me to take the problem to a friend with a scanner to be sure. Turns out the ICP Sensor had failed and after a few minutes and a little too much money, problem solved in the parking lot of my friend’s shop.
Costs more than the $0.25 mod, but absolutely quicker!
Lesson here- look at the exahust for temp before jumping in.
Drivers side is off....well kinda, got that last bolt to take off in the very back, but the plug is still attached.....I hope the passenger side is the one with the problem..
what do I need to tighten while I am in there? And to what ft. lbs? THANKS for all of the help and answers
