Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
a/c problem
Old Sep 1, 2010 | 04:56 PM
joecass's Avatar
joecass
a/c problem
does anyone know why my a/c won't blow out of the dash vents on acceleration-it blows super cold so not a freon issue.
Old Sep 1, 2010 | 05:58 PM
wptski's Avatar
wptski
If vacuum actuators are used to operate(close/open) vents? Vacuum drops on acceleration, so they may move for some reason.
If your old enough to remember, windshield wipers were vacuum operated, so they stopped on heavy acceleration.
Old Sep 1, 2010 | 08:53 PM
scott91370's Avatar
scott91370
I would bet that under the dash one of the vacuum lines has come loose or has a hole in it. Look under both sides (passenger & drivers) for a plug where 5 or 6 lines come together. And also look for the actuators. Or there could be a vacuum leak under the dash or hood.
Old Sep 2, 2010 | 08:11 AM
martin_csr's Avatar
martin_csr
Also, you could check the vacuum line in the engine bay & trace its route to the firewall toward the interior of the car.
Old Sep 15, 2010 | 09:10 AM
MMSCHWE's Avatar
MMSCHWE
A/C Problem
Can you give more detail on how to find a vac leak? Where do I look under the dash? What do the vac lines look like?
My problem seems to be related to the doors that control the air flow. The drivers side gets all the cold air from the A/C, and all the warm air when the heater is on.
Are those doors vacuum-operated?
Old Sep 18, 2010 | 09:12 AM
tonyford's Avatar
tonyford
Had the exact same issue with my 2003 Escape.
Vehicle was still under warranty and all it was was a vacuum line had become disconnected that holds open the deflector doors to control where the air flow is directed.
The service manager told me I could of waited for the vehicle instead of leaving it there all day.
Old Sep 19, 2010 | 08:05 AM
rickfar's Avatar
rickfar
I have a 2006 xlt and mine does the same on acceleration but didnt ford design it that way to give you more power for quick acceleration? as I thought it was normal ......
Old Sep 19, 2010 | 09:07 AM
wptski's Avatar
wptski
Yes, on some vehicles during WOT the A/C is disabled but I have no idea which ones.
Manuals mention but don't list them, is some vehicles, the torque converter is unlocked under WOT also. The ON/OFF cycling time of the A/C clutch is monitored, if done too often it disables the clutch as not to damage the torque converter.
mshargrave23
Sep 15, 2013 12:02 PM
race39
Mar 29, 2012 11:59 PM
sportsmansteve
Jul 20, 2011 10:28 PM
mbjones99
Jun 19, 2011 09:06 PM
snoschu
Jun 21, 2010 09:49 AM
