E4OD problem....maybe
Old Sep 5, 2010 | 08:34 AM
rla2005's Avatar
rla2005
Ok, I understand now. Another item to check if the transmission still acts like it is slipping is the MLPS (Manual Lever Position Sensor). This is an input to tell the PCM where the shifter positon is at. If it sends the wrong info the PCM could be telling the trans. the wrong thing to do. If the MLPS signal is out of range it will pop an error code, but in some cases the MLPS can still have issues without flagging a code. The MLPS will not affect the rough running engine problem.
The MLPS is located on the driver side of the transmission. Check/clean the connections to it.
Old Sep 5, 2010 | 09:26 AM
Encho's Avatar
Encho
The Southernmost Mod
If the computer says it's getting proper signals from all the sensor, you can rule them out as the cause of the roughness, that's a good thing.
Old Dec 26, 2010 | 11:33 AM
jbas's Avatar
jbas
Update:
My issue endedup being the PCM. I happened to have one that I purchased with a superchip. I put it in because I kept having the issue intermittently. It has been four months now and it has not happened since.
Old Dec 26, 2010 | 02:40 PM
mdula's Avatar
mdula
Originally Posted by jbas
Update:
thanks for the update! Glad its working for you.
Old Dec 30, 2010 | 07:14 PM
jjsfrd's Avatar
jjsfrd
Good news. What I want to know is, how do you know when it's bad or going bad?
J
Old Dec 30, 2010 | 07:55 PM
96f350az's Avatar
96f350az
lucky. i wonder if mine went bad? i had nooo sign of my tanny goin bad until today. now no go
Mark Alligood
May 25, 2013 07:10 PM
keiser
May 23, 2013 03:03 PM
haukin99sdp
Jan 18, 2013 10:05 PM
ralphtruck41
Jan 15, 2013 01:11 PM
MuddinTruckF-250
Jul 29, 2010 02:07 AM
