Sponsored by: Real Truck
Power window woes
Old Aug 31, 2010 | 03:44 PM
drew213F250SD's Avatar
drew213F250SD
Unhappy Power window woes
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
The other day my passenger side power window started acting up, at first it did not want to roll down but would go up. Then when I had the drivers side door open it would go up or down. The next day it would only go up even if I had the door open but if I opened and closed the drivers door a couple times it would go down. Now no matter what I do the window will not go down just up, I first figured it was the wiring in the driver side door, so I pulled the boot out from the door and checked all the wires but could not find any broken or rubbed. Then I thought maybe it was a fuse but was unable to find any fuses blown and still I cannot roll down my passenger side window. If somebody has some input on this it would be greatly appreciated.
Old Sep 1, 2010 | 10:58 AM
aMw_fl's Avatar
aMw_fl
I'm having the exact same issues...I've replaced the driver side switch, motor, and I'm fairly sure it is the passenger side switch I guess. I don't know what else it could be.
Old Sep 1, 2010 | 11:06 AM
rotun's Avatar
rotun
Reads ***** rules!
You'll have to put a test meter on the leads going into the motor and then activate the switches. The polarity will change whether going up or down so you will need a meter that shows polarity. If you are getting the voltage at the motor leads then the switches are probably fine, test using both switches (drivers door/ pass. door). Usually it is one or the other that is bad, not the motor.
rbrad6937
Jun 3, 2018 12:06 PM
drew213F250SD
Aug 31, 2010 08:17 PM
FordF350Baby
Nov 14, 2009 04:04 PM
WheredaFoxhat
Dec 24, 2005 07:14 AM
mistakenID
Nov 7, 2005 08:19 AM
