Identification help
Old Sep 2, 2010 | 12:39 PM
NorthernDiesel's Avatar
NorthernDiesel
When I get home later this afternoon I'll go look it up and let you know what you have to join.
Old Sep 2, 2010 | 02:22 PM
Gotitcheap90's Avatar
Gotitcheap90
okay thank you
Old Sep 3, 2010 | 06:17 AM
NorthernDiesel
After looking last night, I realize its actually a 6-pin connector not 4, anyway, heres' what it looks like.
Here's the module:
The Banks harness runs from the module to the tranny behind the small heat shield:
This is the arrangement behind the heat shield:
This is where the module connects to the Banks harness; the shunt goes in place of the black side of the connector (goes in the grey side):
The shunt looks like this:
In my Banks harness I have wires Black, Red, Orange, Brown and Yellow.
The wire in the shunt connects the Orange to the Yellow. Solder these two together and seal them up, that'll return the tranny to normal.
If you wanted to return the wiring to stock, look at the wiring in picture 3. The cloth-wrapped harness should run into the tranny connector only, the rest is part of the add-in. During the install you rob three wires from the tranny harness, and add them to the black connector, and wire some from the black harness into the tranny connector. If you want to revert this, go to the Banks site, they have the manual for TransCommand for E4OD, in it theres a diagram you can backtrack to find where the pins in the black connector should be in the tranny connector.
Old Sep 3, 2010 | 11:52 AM
Gotitcheap90
that is a awesome write up ! I will go ahead and connect those two wires today and take her for a spin, thats exaclty what my harnes coming off my tranny is i have those exact colors. If only i knew that it was a transcommand when i tossed it off becuase it looked broke lol So today i will be searching the whole property but when that fails ill just connect them, ill be back on later to let ya know how it turned out ! thank you very much
Old Sep 3, 2010 | 11:59 AM
NorthernDiesel
NP, hope it works for you!
Old Sep 3, 2010 | 04:15 PM
Gotitcheap90
well good and bad news. I had spliced together the yellow and orange wires. It made a difference tranny seemed to be alot smoother and drive alot better but still once i hit overdrive it seems to be locking up and unlocking ? What should i try now like i said tho it deff. made a good difference connecting those two
Old Sep 3, 2010 | 10:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Brake lights unlock the converter.
Do your turn, brake and tail lights all work right?
Do you have a trailer wiring harness/connector on your truck?
Old Sep 3, 2010 | 10:24 PM
Gotitcheap90
yes all lights are working and yes I do have trailer lights but I havnt used them yet. I have noticed my symptoms occur after I have driving bout 5-10 miles like once it heats up it acts up ??
Old Sep 4, 2010 | 12:18 AM
Dave Sponaugle
Kinda where I was going with the trailer wiring connector, a short in there can back feed through the brake light circuit and cause the torque converter to unlock.
Bad grounds in the tail lights, same thing.
There have been a few posts about some rather strange electrical issues causing the torque converter to unlock.
Old Sep 4, 2010 | 11:47 AM
Gotitcheap90
Okay ill get under there and trace them, I know I have that "T" the goes inbetween the brake lights to add a trialer harness so Ill just unplugged it and plug them in normal and see if that fixes it ! thanks for you tip
Pokee
Mar 29, 2017 04:12 AM
crash113
13
Jan 31, 2017 01:41 PM
Rusty36
Offroad & 4x4
Apr 24, 2012 12:46 PM
tholt34
16
Jan 14, 2007 08:45 PM
jb1390
41
Jan 19, 2006 06:47 PM
