Identification help
Old Aug 30, 2010 | 09:48 PM
Gotitcheap90's Avatar
Gotitcheap90
Identification help
This i believe is transmission related. WHen i first got my IDI i noticed a small black box hangin underneath the truck, it was right by the tranny the box is maybe 3-4 inch by 3-4 and maybe 1 inch thick? I was all cracked full of mud and run over ( kids use to mud this truck). Anyways what could this box have been ? My tranny shifts fine but seems like the converter locks up and unlocks when in 3rd and overdrive ??? please help
Old Aug 30, 2010 | 09:51 PM
rupejosh's Avatar
rupejosh
that sounds like it is the mlps (neutral safety switch) it thats messed up it can and will cause issues
Old Aug 30, 2010 | 10:31 PM
powerstroker100's Avatar
powerstroker100
my tq will lock up right when it shifts into third and then will unlock, locking will be like 1900 then drop down to like 1500ish +/- also my reverse lights do not work? don't mean to hijack
Old Aug 31, 2010 | 05:29 PM
Gotitcheap90
BUMP, no problem we are all here for help. Could anybody else add some input to my question and also powerstroker100 ??
this mlps. is it a rectangular box underneath the truck by the tranny ??
Old Aug 31, 2010 | 05:50 PM
Otahyoni's Avatar
Otahyoni
The MLPS would be mounted to the (drivers) side of the transmission and have the shift lever going through it.
Old Aug 31, 2010 | 07:33 PM
David85's Avatar
David85
The little black thingy on the side of this transmission is the MLPS (manual lever position sensor):
It also functions as the neutral safety switch and the back up lamp switch.
Old Aug 31, 2010 | 10:47 PM
Rick Wallace's Avatar
Rick Wallace
My turn to highjack, does the C-6 have a switch like that for back up lights as well?
Old Aug 31, 2010 | 10:51 PM
wreckinball's Avatar
wreckinball
yes it does and in a similar spot.
NSS for C6
Old Aug 31, 2010 | 10:53 PM
greywynd's Avatar
greywynd
Similar spot, looks more like a donut with an electrical connector.
Old Aug 31, 2010 | 10:57 PM
Rick Wallace
Cool,,Thanks
Old Aug 31, 2010 | 11:16 PM
Gotitcheap90
Thanks for the picture now i can remove that MLPS from the list. That IS NOT what im looking at, this box was just hanging from the passenger side only thing going to it were wires to a plug so i just unplugged it becuase is was all cracked and run over. i would try to post a pic BUT it was tossed in the scrap pile for some reason and now i have to just go off my description and hope someone knows what im trying to explain
Old Sep 1, 2010 | 07:24 AM
NorthernDiesel's Avatar
NorthernDiesel
Is it an E4OD?
Was it near the wiring running into the tranny at the aft passengers side?
Did it have just one 4-pin connector coming out of it (3 or four wires)?
If this all checks out, it sounds EXACTLY like a Banks TransCommand module.
If it was originally connected to your current tranny harness, the harness coming into the tranny should have a 4-pin connector hanging out of it near the main connector (hidden behind a small heat shield). If the module is disconnected, there should be a shunt in the harness side that effectively bypasses the mod.
The unit looks like this:
(Seems like diesel units are plated steel while gassers and older units may have been black, but dont quote me on it)
Old Sep 2, 2010 | 11:18 AM
Gotitcheap90
Im pretty sure your exactly right! thank you! now with the module unplugged would that be cuasing my converter to be goin crazy ??? if so how do I fix this problme ?
Old Sep 2, 2010 | 11:55 AM
NorthernDiesel
It pretty sure it would.
During the install, you divert some wires into the 4-pin connector on the harness that connects to the TransCommand module. If you remove the module, that circuit is open, and this is the circuit that controls clutch line pressure in the tranny.
Bypassing this is the purpose of the shunt; its a 4-pin connector that goes on the matching 4-pin connector near the tranny harness. All it has is one wire, connecting one pin to another to complete the circuit as if there were no connector there at all.
Take a look on your truck, if the shunt isn't there, you'll want to either manually shunt it (solder two of the three wires together) or re-attach the module, if it still works. If you want to do this let me know, I can look up which two wires it is that you have to solder together. Even better, if the connector on the harness is in good enough shape, you can pull the wires and return it to factory arrangement, removing all traces of the module.
If the shunt is there or someone already shorted the wires, there's something else unrelated wrong. If the connector isn't there, someone already pulled the wiring, and your tranny has other issues (maybe they pulled the wiring and put it back together wrong!)
Old Sep 2, 2010 | 12:05 PM
Gotitcheap90
The whole line pressure thing sounds exactly like whats goin on, it like will build enough to lockup and unlocks over and over which is probly not good at all on the tranny yet very annoying especially when your date goes "Whys your truck driving so funny" haha anyways right now when i crawled under there i have the plug where i had unplugged the module which runs up the the passenger side of the tranny, I believe the dead giveaway that this is the module kit is becuase theres a ground wire with a connecter thats not factory goin to a ground. so as of right now i have a open plug harness coming from my right side of the tranny. Your help is very very apreciated ! So yes if you could walk me through which wires i should connect in this plug. I still cannot find the module ( pretty sure it got thrown away)
thanks again !
