Need a Flywheel NumberDummy?
Old Aug 30, 2010 | 09:03 PM
Broomfieldbum's Avatar
Broomfieldbum
I have a question about a part on ebay. I need to get a flywheel turned or a new flywheel. I found this one on eBay and thought it might be a good buy. The guy claims it is for a 240/300 but I trust NumberDummy more, and the ad has a casting number. I don't know it can be translated, but if anyone knows NumberDummy does.
1964 1971 FORD 240 300 6 CYLINDER FLYWHEEL: eBay Motors (item 350340108008 end time Sep-09-10 14:01:19 PDT)
Old Aug 31, 2010 | 02:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The guy claims it is for a 240 / 300 The ad has ID engineering numbers. I don't know it can be translated, but if anyone knows NumberDummy does.
Another clueless ebay seller. No such thing as a 1964 anything with a 240/300. / Passenger Car only 240 I-6 flywheel.
Marked C6AE-6380-C and/or C7AE-C = C5AZ6375R .. Flywheel-164 teeth / (6) 5/16" -18 pressure plate attaching holes on a 10 3/4" bolt circle.
Original applications: 1965/71 Galaxie/LTD 240 1-6 w/a 9 1/2" clutch.
Info source: 1965/72 Ford Passenger Car Parts Catalog / Text / Section 60.3 (240) / Page 6.
What size engine does your truck have? How many teeth on the flywheel: 164 or 184?
What size clutch does your truck have: 10 inch or 11 inch?
240/300's in F100/350's could have either number of flywheel teeth, or a 10 or 11 inch clutch.
ID engineering numbers can be cross referenced to actual part numbers (casting numbers cannot).
If ID numbers are marked on flywheels, they are listed along with the flywheels in the Text-engine sections (6000) of Ford car/truck parts catalogs.
Old Aug 31, 2010 | 07:56 AM
Broomfieldbum
Thanks ND, I knew you would know the answer. Considering everything that has been modified on my truck, I think I will pull the clutch and flywheel and do some measuring before I even open the clutch I bought. The guy at Advance Auto said I have an 11 clutch.
So if I have an 11 inch clutch would this part fit? The reason I am looking at a new flywheel is I know there are teeth missing from mine, and I cannot find a place to get mine turned for less than this guy wants.
Thanks again for the good info. I knew the 64 part was bunk. 65 was the first 240 I ever heard of.
Old Aug 31, 2010 | 08:22 AM
NumberDummy
Absolutly not! It's a passenger car flywheel only for a 9 1/2" clutch, the bolt pattern is 10 3/4 inches.
How does the guy at Advance know you have an 11" clutch? What does he have, x-ray vision?
Most 240's I've seen had a 10" clutch...if you have a 300, it's prolly an 11 inch...but who knows after 40+ years what's there today?
C8TZ6375A .. Flywheel-Use with 10" clutch / (6) 5/16" -18 pressure plate attaching holes on a 11 3/8" bolt circle.
C5TZ6375E .. Flywheel-Use with 11" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle.
How can you bolt an 11 (or even a 10) inch clutch on a flywheel that has a 10 3/4" bolt circle?
You can buy the flywheel ring gear by itself. The old one has to be "sweated off" the replacement sweated on. Autoparts machine shops can do this.
Old Aug 31, 2010 | 07:19 PM
garbz2's Avatar
garbz2
Standard/Flywheel - Manual Transmission (717) | Flywheel - Manual Transmission | 1966 Ford F100 1/2 ton P/U 2WD 6 Cylinders 3.9L 1BL OHV | AutoZone.com
Here is a new one from Autozone. Did the counter guy tell you they have new ones? you cant get it surfaced and re hooped for that.
Garbz
Old Aug 31, 2010 | 07:20 PM
garbz2's Avatar
garbz2
Here is a new one from Autozone. Did the counter guy tell you they have new ones? you cant get is surfaced and re hooped for that.
Garbz
Old Aug 31, 2010 | 11:02 PM
Broomfieldbum
Thanks Garbz, I will look into that. I would rather get the newer parts.
ND, If I get a new Flywheel that takes a 11" clutch, I can just install it right? The reason I ask is I have replaced every mechanical thing on this truck except the engine, and I plan to put a 300 in it when I do replace the engine. So I would like to have the 11" clutch if possible.
Old Sep 1, 2010 | 04:33 PM
Broomfieldbum
Just pulled my truck apart, and the flywheel has DEEP grooves. It may be able to be turned, but if it can it will turn to minimum spec. So I am going to try and see if the flywheel AutoZone (Garbz found it) has will work for me.
NumberDummy, am I right in thinking that if both 10 and 11 inch clutchs were offered on these 240/300 engines, if I buy all 11 parts, I can bolt them up, and then when I change the 204 out for a 300 I will have a 11 inch clutch as I should. Let me know if you get a chance.
Old Sep 1, 2010 | 08:23 PM
garbz2's Avatar
garbz2
Bum,
Most new flywheels are drilled for either pattern. Unbox it on the counter and match up an 11" unit.
Garbz
Old Sep 2, 2010 | 11:01 PM
Broomfieldbum
Garbz,
While the online store and the retail store may be able to look up a part number for a flywheel, when you go into the store they tell you, "We can't get this part anymore." So I ordered a new one from Green sales for twice the price. At least I know the number is right since it came from NumberDummy. Should have it in a few days, and then I can reassemble.
Now I need to get on top of cleaning an painting the parts I took off, like the Bell Housing and the Transmission, and back brace for the tranny. I haven't decided on the Drive Shaft yet. I don't want a show truck, but a rust bucket is too far the other way too.
Old Sep 4, 2010 | 07:43 AM
DAVTruck's Avatar
DAVTruck
Flywheel torque?
I have a 1966 F250. I got a new clutch and flywheel but I don't know the correct torque. Can someone help me out? Thanks....
Old Sep 5, 2010 | 04:55 AM
Old_Crow's Avatar
Old_Crow
Bum, I once bought a '53 F100 that the previous owner had painted the drive shaft like a blue and black barber pole. I guess he used left over paint from the engine, because the engine was blue and the trans was black.
Looked silly as heck, but I *know* it took a lot of work to tape it off right.
1986F150six
May 5, 2017 02:16 PM
1986F150six
Jun 8, 2016 03:54 PM
Doubleclutch
May 17, 2016 08:06 AM
vincenthp
Mar 20, 2016 08:46 PM
Broomfieldbum
Jun 27, 2010 12:05 AM
