Another exhaust system question
Old Aug 30, 2010 | 08:12 PM
richartdana44's Avatar
richartdana44
How difficult is it to disconnect the downpipe at the turbo?
Now that I have my new system on order I am thinking about the install this coming weekend. With over 200,000 miles on the stock downpipe it has seen many heat and cooling cycles.....
Any suggestions on breaking this connection without busting any bolts?
Old Aug 30, 2010 | 08:30 PM
rbaker6336's Avatar
rbaker6336
Soak everything down good with PB Blaster
Old Aug 30, 2010 | 08:34 PM
Ponyboychris's Avatar
Ponyboychris
I sprayed PB Blaster the night before and it popped right off.
Old Aug 30, 2010 | 08:38 PM
WMDPSD's Avatar
WMDPSD
mine had 153,000 miles on it when it was popped off the first time and with some kroil (sp?) it came right off
Old Aug 30, 2010 | 09:38 PM
big poppa's Avatar
big poppa
What the guys said, PB Blaster or WD-40 is your friend. Soak it good for the next morning. A long screwdriver and a bump with a hammer will do it.
Old Aug 30, 2010 | 10:37 PM
binuya's Avatar
binuya
After loosening the clamp at the turbo, I took a sawzall to it at the lower end. Besides making it easier to take out, it created a lot of vibration which helped it to break loose.
Old Aug 31, 2010 | 10:24 AM
richartdana44
Great advice, thanks. Good idea using the sawsall!
Old Aug 31, 2010 | 11:51 AM
robs01f250's Avatar
robs01f250
Don't know how I did it but I didnt have to use any wd-40 or pb blaster.
Old Aug 31, 2010 | 12:00 PM
just another truck's Avatar
just another truck
PB Blast 24 hours before,Loosen the clamp, Sawzall, pry bar in the end of the pipe and rock it. My buddy and I did my exhaust in 45 min, removal and installation here in the parkinglot of my shop.
randle_ford
21
Dec 15, 2019 04:13 PM
strokin71
Feb 5, 2009 05:10 PM
watermanh
16
Jun 10, 2005 04:35 PM
wrangler76
Feb 7, 2005 06:44 PM
Andywk
17
May 7, 2003 09:29 PM
