Sponsored by: Real Truck
rattle from exhaust.....
Old Aug 29, 2010 | 08:28 PM
WorkhorseF250's Avatar
WorkhorseF250
hey boys got a question for you. i have a rattle on the exhaust of my f250 5.4l 2006 and want to know if the heat shield on the muffler at the back is needed? it is viberating or rattling. cleaned rocks out of it but hasnt fixed it.... please let me know if you have a way to get rid of this
also on a side note i put up a few pics of the truck with the trailer mirrors and bug deflector and new tires.
Old Aug 29, 2010 | 08:35 PM
GUNNERDOG's Avatar
GUNNERDOG
IMHO if ford put it there it is needed... although i just had one fall off (the one you can see through the front passenger side wheel well) and i haven't replaced it yet.
Any muffler shop can weld it back on for you.
Old Aug 29, 2010 | 08:38 PM
scraprat's Avatar
scraprat
Top Answer: 5
I had the a couple of the welds break and just used a large metal hose clamp, rattle gone.
Old Aug 29, 2010 | 08:44 PM
WorkhorseF250
this is at the back of the truck. can be seen from the passenger side wheel well. it looks to be just a heat shield or something. held on by two metal straps.
Old Aug 29, 2010 | 08:45 PM
BCHauler's Avatar
BCHauler
I have the exact same issue with the 01 f250 I just bought. I also thought it was the heat shield. Which welds are you referring to?
Old Aug 30, 2010 | 04:47 AM
scraprat's Avatar
scraprat
Top Answer: 5
On the front of the pipes, either side of the oil pan/engine area there are heat shield that are tack welded on.
Old Aug 30, 2010 | 04:49 AM
scraprat's Avatar
scraprat
Top Answer: 5
Are you talking about the muffler itself with the shield around it and the 2 metal straps?
Old Aug 30, 2010 | 08:16 AM
WorkhorseF250
yes that would be what im talking about. the metal straps holding it on. any advice on how to stop it from rattling.
Old Aug 30, 2010 | 08:55 PM
WorkhorseF250
anybody else know if theres a solution to the shield on the muffler at the back of the truck? its not welded on just strapped on. would it be bad to take it off?
Old Aug 30, 2010 | 09:02 PM
acf6's Avatar
acf6
Im not sure how to fix it but i think i have the same problem i havent looked under there yet.. i get a rattle right before it shifts from first to second and sometimes second to third. hopefully thats the problem
Old Aug 30, 2010 | 09:53 PM
GUNNERDOG's Avatar
GUNNERDOG
Sounds like your options are:
1) remove and hope it doesn't melt something.
2) try to fashion something (maybe out of band clamps) to hold it on tighter.
3) take it to a shop and tell them to fix it.
Maybe take a few pictures and post them up, perhaps that will inspire a solution.
jerem0621
1997 - 2003 F150
Mar 23, 2012 09:17 PM
wizzy214
Feb 16, 2012 07:06 AM
GreatNorthWoods
22
Oct 4, 2007 07:32 AM
Fard
Sep 4, 2007 05:20 PM
nnypoptart
Dec 18, 2003 12:29 PM
