Stopping Rattles - 48 F-3
on
I've been chasing rattles in my 48. One significant rattle is under the dash. My stock vacuum windshield wiper arm lever that operates the passenger side wiper rattles! I don't know how I'd stop it from rattling since anything done to stop it might bind it up. Anyone else run into this? The wiper works great otherwise. I'm also hearing rattles in the doors. What might be rattling in there and what, if anything, have you done to stop those?
on
1 Post
For the wiper arm try applying some heavy grease lubricant to the pivot joints so as to form a film between the two metal parts. The rattle in the doors are likely due to the window regulators being loose. You may need to install a new anti-rattle kit or use a similar technique of lubricating the moving parts within the door.
on
Originally Posted by 4tl8ford
Vern, Vern, Vern,------
Them Rattles got part numbers on them, look in the back of the parts book, their right by the Flathead V8 Engine block crack numbers.
I think the fact that the 48-50 trucks have no upholstery on the door panels exaggerates the noises...
Rattles
Two part rubber coating that sets up.Just a dab will change freq.of noise or coat all of it. Flexible or rigid tubing made of rubber or plastics. Ie: surgical tubing. How about plastic soda straws you find at Burger King/Mc's/Wendys etc. I've seen aluminum tubing with a rubberized clear coat. Hope this will give you ideas. Have a great day,chuck
Actually, a lot of rattles are because the distance between the two anchor points is such, that the piece in between "floats" in between them. This allows it to rattle, as it vibrates in the holes. One good remedy is to either lengthen or shorten the piece in between, by either putting a slight bend in it, so that it shortens it enough, that it rests on the inside of the holes at all times, eliminating the rattle, or using a plastic bushing in the hole, so it doesn't rattle. The other way is to increase the distance very slightly of the anchor points, doing the same thing, so that it's under very slight pressure in the holes, getting rid of the rattle.
30 years of working on a myriad of equipment has taught me this.
R
R
GNW, does your linkage have the spring clips on each end? If they were good and tight, I would think that would stop the rattle on the wipers.
The window regulators are a pain. They are pretty cheaply made, I mean no actual bearings you could replace. I've seen people stuff a roll of leather in between the pieces to shut them up. Maybe dense foam would work too?
Vern,
Ok, you've had alot of advice already on this but I have the definative answer for you for the wiper arm rattle. Remove all the offending passengers side related wiper parts, wrap them tighlty in bubble wrap and package them in a box and mail them out here to the deserts of New Mexico. I'll sacrifice my sanity and dillagently drive my truck around with your annoying rattles. No, no, really, I don't mind. It will be worth it to me knowing that you are able to drive your truck around in peace and quiet.....
Bobby
Bobby
No problem, just trying to help a fellow FTE'er out. I wouldn't make the sacrifice for just anybody
I've been searching for the stock passenger side wiper linkage for my 49. I'll convert it to electric but it would sure be nice to start with the factory linkage.
Here's another suggestion for your rattles----Get a better sound system! Then crank the volume ****, rip it of and toss it out the window...problem solved (I know, I know...I'm alot of help huh?)
Good luck with it
Bobby
Good luck with it
Bobby
