74 f100 blinker problem
Old Nov 14, 2010 | 08:48 AM
LittleG's Avatar
LittleG
Fluid level is ok . Here's a question ... What is the purpose of the wires that connect to the brake portioning valve? Could this have something to do with the problem. It appears everthing else works. I just added PS,PB and Auto trans to this truck and the only thing left to finish are these stubit blinkers.
Old Nov 14, 2010 | 12:09 PM
Nathan Plemons's Avatar
Nathan Plemons
I wouldn't know for sure without looking at the wiring diagrams, but it would seem to me that those wires would have something to do with the "brake" indicator lamp on the left side of your gauge cluster. Not sure exactly what it monitors but it does light up momentarily when I start my car.
Old Nov 14, 2010 | 12:48 PM
thatsrealnice's Avatar
thatsrealnice
There's a brake fluid indicator switch that those wires connect to, and that switch indicates if the fluid distribution is off. A lot of times though, the switch that goes into the proportioning valve which those wires plug into are faulty. They're made of plastic, and leak, which makes the brake light come on in the cab. I doubt that is the problem with your turn signal issue. I was having some problems with mine, here's the link to the thread on my turn signal/brake issue.
https://www.ford-trucks.com/forums/9...t-problem.html
Old Nov 14, 2010 | 01:59 PM
juchertf100's Avatar
juchertf100
have not fixed it yet i belive it the switch ive tried everthing else i found a switch out of a f4 i hope it will work
rossseger
Nov 3, 2014 02:09 PM
fosgatekc
Oct 3, 2011 11:11 AM
69monster
Electrical Systems/Wiring
Apr 16, 2010 02:13 PM
jennmanski
15
Nov 7, 2007 02:50 PM
wmsteward
Oct 15, 2007 11:44 PM
