Blinker works, brake light doesn't
Old Apr 16, 2010 | 10:25 AM
69monster's Avatar
69monster
I have a 69 F100, yesterady i was told that my driver side brake light was out. Wanting to check this I turned on the blinker and it worked. Next I wedged my ice scraper between the seat and pedal, no drivers side brake light. Since these two are both ran from the same wire, do you think my problem is in the blinker switch?
Old Apr 16, 2010 | 01:38 PM
gearloose1's Avatar
gearloose1
Your bulb is out.
Change the bulb.
Old Apr 16, 2010 | 01:41 PM
69monster's Avatar
69monster
The blinker and the brake each use the same filament in the same bulb, what would replacing it do, the blinker works?
Old Apr 16, 2010 | 02:13 PM
Franklin2's Avatar
Franklin2
Yes, I would suspect the turnsignal switch. Your logic is correct.
will32_
24
Sep 28, 2014 10:18 PM
Desert Soldier
Jul 16, 2013 01:24 PM
LV2HNT
Jan 25, 2013 06:52 AM
vol1966
Feb 20, 2011 11:01 AM
69monster
Apr 22, 2010 12:51 PM
