74 f100 blinker problem
Old Aug 29, 2010 | 07:08 PM
juchertf100's Avatar
juchertf100
I have a 1974 f100 4x4 ive got a problem the blinkers have stoped working, the hazzaards are still working , ive checked the flasher and it worked in th hazzard fine so i assume thats not the prob so what do i check now , is there a way to check the switch its self....
Old Aug 29, 2010 | 07:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If the hazards still work okay that would indicate that the wiring, grounds and bulbs are okay.
Do both brake lights work okay? With your foot on the brakes, when you turn the turn signal on does the brake light on that side stay lit or does it go out?
Old Aug 29, 2010 | 07:26 PM
juchertf100
the light does go out with the blinker on and when you turn the blinker off it comes back on.....
Old Aug 29, 2010 | 07:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Have you checked the bulbs in the front parking lights?
I know you checked the flasher, but the symptoms sound like a bad flasher.
Old Aug 29, 2010 | 07:56 PM
juchertf100
i just replaced bolth flashers and still same problem i have checked all bulbs and there all good ...
Old Aug 29, 2010 | 08:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thats kind of narrowing it down to the turn signal switch, but to me it just doesn't sound like the tss.
I'll see if I can dig up a troubleshooting chart for the switch.
Old Aug 29, 2010 | 08:18 PM
SparkyRnD's Avatar
SparkyRnD
try jiggling the lever while the switch is activated and see if they come on (even just barely). It sounds to me like the switch inside the column is either corroded, broken or not making contact.
Old Aug 29, 2010 | 08:21 PM
juchertf100
i tried wiggling the lever and nothin..
Old Aug 29, 2010 | 08:30 PM
SparkyRnD's Avatar
SparkyRnD
You can pull a multimeter at the base of the column and see if there is power when the switch is activated. If not, you need to take the column apart most likely.
Old Aug 29, 2010 | 08:46 PM
juchertf100
sparky do you know which wires to check
Old Aug 29, 2010 | 08:51 PM
jetfxr74's Avatar
jetfxr74
I know it sounds simple, but have you checked the fuse? The flashers and blinkers work off of a different power supply. I just had the same problem and the fuse was blown. Forgive me if you have checked that already. Sometimes the simple solutions are the hardest to find.
Old Aug 29, 2010 | 09:21 PM
juchertf100
the first thing i checked is the fuse ...
Old Aug 29, 2010 | 09:27 PM
SparkyRnD's Avatar
SparkyRnD
not sure which wires to check. is there a diagram online somewhere?
Old Nov 13, 2010 | 03:43 PM
LittleG's Avatar
LittleG
Juchertf100
Did you ever get your problem fixed? I have the same issue with the same symptons but I can't figure out what's wrong.
Gene
Old Nov 13, 2010 | 05:35 PM
Nathan Plemons's Avatar
Nathan Plemons
Did you check your blinker fluid level? It uses the power steering reservoir.
Seriously when I got my truck it had sat for so long that a lot of stuff didn't work just from oxidized connectors and such. I took the dash apart and got everything working like a champ, replaced a few burned out bulbs, etc. One day I drove the truck and I noticed that the power steering started making a little bit of noise, and around the same time I noticed that my turn signal worked, but the dash indicator light didn't work. I got to where I was going and checked the power steering fluid, sure enough it was low. I filled it back up and magically the turn signal indicator started work. Proof positive that it must have been low on blinker fluid!
Actually it quit working again and I had fixed the power steering leak and the level was full. I tore into the dash expecting to find a blown bulb but it wasn't. Turns out that the little plastic thing that holds the bulb wasn't making good contact. I cleaned it's contacts with contact cleaner and some 2000 grit sand paper and put it all back together and it works fine.
Probably won't help you any, but I thought I would share anyway. To the un-trained idiot it sure would have seemed like a blinker fluid issue!
